Engine water pump frustrations
Old 09-06-2014, 09:36 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
After replacing all 3 idler pulleys, both tensioners, water pump pulley, supercharger pulley (and changing the bearing) plus the crank pulley and adding an extra pulley in the form of a belt wrap kit I discovered my engine water pump pulley was loose so began looking online for a replacement. I was surprised to discover out of all the parts I have purchased and researched for the E55 this water pump was by far the most difficult to find. Even the few threads I found referencing the W211 E55 pump indicated it was not prone to failure and therefore not kept in stock by various online parts stores and dealers. Adding to the scarcity it appears all W210 and W211 E Class models use the same engine water pump with the only exception (because of the supercharger) being the W211 E55.
Anyway i eventually found an eBay retailer that sold the pump so did their compatibility test to ensure it was indeed the correct part and once confirmed placed my order and it arrived promptly a few days later.
By chance my alternator had given up the ghost last week so swapping out both at the same time was going to be convenient - or so I thought till last night when I discovered they had actually incorrectly sent me the other more common pump for every other E Class! It is similar in most ways but is missing the entire section where the 2 idler pulleys attach.
Hopping back online I found out a couple of other people had the same wrong part sent to them also. I'm unsure what their ultimate solution was though it appears even some retailers are confused about the suitability. After another extended search session I was still unable to locate the correct pump!
So today I have decided the best solution if possible will be to simply remove the pulley from the new pump and install into the old one.
Has anyone here had a failed engine water pump and how did you deal with it? Does anyone else have any suggestions? I am quite surprised at the scarcity of this particular part.
Old 09-06-2014, 10:18 PM
O-55's Avatar
2005 E55, 2009 VW GLI
What was the part number of the water pump you received? I see 113-200-01-01 as being the water pump for our cars.
Old 09-07-2014, 08:09 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
I just bought one from pelican parts on my last round of preventative maintenance. I had to tap two blank holes, but they were tapered and self aligned the taps for me. It's a rebuild, but I'm content with the quality.
Old 09-07-2014, 02:11 PM
Hello Artist is there any chance you could post a picture of your handiwork so I can compare the units. I'm gonna have to work some sort of solution over the next 12 hours.
Cheers!
Old 09-08-2014, 06:11 AM
There is nothing to see. It was identical to the original except two holes were blanks where they should have been threaded for the idle pulley bolts. A mistake. If I remember right it's a 8x1.25mm and a 10x1.50mm. Might not happen to you.
Old 09-08-2014, 06:47 AM
Ah the one sent to me is missing the entire section where the idler pulleys attach. I have looked on Pelican Parts even using the OEM part number and the wrong model (like the one I was sent) also comes up there. It's like the entire internet has the wrong part. We are trying to swap the pulley part around now but I think we might have stuffed both and I'm supposed to leave town last week! It will take a week to send it to me from the Mercedes on the other side of Audtralia and cost literally 10 times more plus what I've already spent. Looks like I could be pushing the car to the next town!
Old 09-08-2014, 07:15 AM
Try cls55 in your search. 1 year only, so maybe less confusion, but same pump.
Old 09-08-2014, 08:23 AM
Very clever I'll give it a go!
Old 09-08-2014, 09:20 AM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Here ya go, straight from the Mercedes service system
The one below is the one for all of the other models. Also, given your time constraint you probably just want to swap them out, but these water pumps are rebuildable... the flange, seals, impeller, and sleeves can all be ordered separately.
In reference to the two holes that needed to be tapped, those were likely self tapping fasteners from the factory. The service parts should have come in with tapped holes but some slip through the cracks. The R&R (remove and replace) instructions probably state a torque for a self tapping fastener and a different torque for a standard fastener.
Old 09-10-2014, 01:38 AM
Two screw's Avatar
'05 E55 Designo
Hi Guys. First post here. I bought that 117-2220 "so-called" exact fit pump...wrong! Now I have to return that one. After a week of trying to find the right one I had enough & bought a genuine MB pump.
The part number I have is 113-200-01-01-80 ( used to end in 88 )
It costs a little more but I don't want to do this job again for a while.
Here is the only source I could find after a week. It's a real correct part and has a good price...
http://www.importecwarehouse.com/Mer...s.htm?CartID=1
Old 09-10-2014, 06:50 PM
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
When I replaced my engine recently I decided to install a new water pump.
I had the same problem with the pump not having the holes threaded for the pulleys.
Sent the first one back and the parts guy worked hard calling everyone to verify the correct part number for my car with the supercharger. Ordered the second one, and the same thing. No way to install the pulleys.
So, I just reinstalled the original water pump and got the engine in.
So, it seems this is an ongoing problem. Very odd when ordered by VIN and the part is over $400.
G
Old 09-11-2014, 10:13 PM
G
Yes this does indeed appear to be a recurring issue for purchasers of the W211 E55 water pump. The pump I bought was amazingly cheap and seemed as good quality as any other more expensive pump. Of course considering it was the wrong shape with no provision for idler pulleys made it less of a bargain.
In the end we used the gasket plus the blade, shaft, flange and other guts from the new pump and installed them into the old pump. The replacement pump was only $48 so only utilizing a few of the parts and throwing the rest away was no biggie.
Leftover parts: The new water pump housing now pillaged and plundered together with the old flange
Old 09-11-2014, 10:24 PM
Came across this bargain while searching for a water pump.
List price: $258
Your price: $304.03
Hmmm apparently I'll get a better price if I don't tell them it's me buying the pump lol.
Old 09-11-2014, 11:06 PM
Two screw's Avatar
'05 E55 Designo
In the end we used the gasket plus the blade, shaft, flance and other guts from the new pump and installed them into the old pump. The replacement pump was only $48 so only utilizing a few of the parts and throwing the rest away was no biggie.
Leftover parts: The new water pump housing now pillaged and plundered together with the old flance
How hard was it to use the cheap donor pump to retrofit your original? I still have my 68$ one on the floor and the costly 403$ MB pump not installed yet. Very interested to know, my old pump is out of the car at 6pm est.
Old 09-12-2014, 12:08 AM
That's actually a great route, well done!
Old 09-12-2014, 12:28 AM
Two screw's Avatar
'05 E55 Designo
It should be a thread & future sticky.
Old 09-13-2014, 03:56 AM
DIY: How to inexpensively repair a W211 E55 engine water pump
For other 55 owners in the same situation here's what we did..
(1) Purchase a cheap replacement pump to use for parts - any W210 or W211 pump can be used. We purchased from eBay seller "velestrumf" for $48.
(2) Follow the instructions below to change-out parts required and install into your current pump housing.
Max.H (05-27-2017)
Old 09-13-2014, 12:32 PM
Two screw's Avatar
'05 E55 Designo
Excellent. Outside the box thinking can save a E55 Man upwards of 300$
I installed my MB genuine part last night but I think I will keep my original core & gmp pump for the unforeseeable future as these 5.5 compressor pump cores get harder & harder to find.
Old 02-06-2015, 03:40 PM
sealrockswell's Avatar
2003 Mercedes-Benz W211 E55 AMG
My tensioner pulley bolt just snapped off inside the water pump assembly and it appears to be nearly impossible to bore it out without damaging the internal threading. So yeah, I'm in the market for a new water pump assembly. This thread has been very helpful, so thanks everyone before me. Just to be clear, is this for sure the confirmed part required? http://www.importecwarehouse.com/Mer...s.htm?CartID=1
Old 02-06-2015, 03:49 PM
Gadget's Avatar
You can try cutting a slot in the end of that with a Dremal and then use a screwdriver to try and back it out.
I would attempt that long before I ordered another pump and go through the work swapping it out.
If you do order another pump, be careful that you check that hole before you install it. I got a couple of new pumps when I did my engine swap and both new ones did not have that hole threaded. I ended up putting the old pump back on.
G
Old 02-06-2015, 05:55 PM
Elhonaz's Avatar
W211 E55 2003
Awesome job therapist! So this pump should be ok to take parts from?
Thanks!
http://www.ebay.de/itm/WASSERPUMPE-K...item35bb76e914
Old 02-06-2015, 06:01 PM
Gadget's Avatar
I do not think that is the correct water pump for the M113 engine. It does not have the provision for the supercharger idler pulley.
Old 02-06-2015, 06:30 PM
Thanks Gadget. Man, what a pain.. So even if I did shell out about $350 for a new pump, and get lucky enough to order the right one and have the right one shipped it may not come pre-threaded!? Wow. This is a bit troubling.
Old 02-06-2015, 07:45 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
Most parts do not come pre tapped on these motors. Oil pans, timing covers, water pumps, etc. The bolts are self tapping and this is the way it is done at the factory as well. Clean the threads on the bolts and put a little lube on and drive them in. Not a big deal.
Old 02-06-2015, 08:34 PM
Thanks!
This should do the trick. Any pump for a W210 or W211 will be fine to pull the guts out and install in your current housing. You will need a press though.
Quick Reply: Engine water pump frustrations
