ARP custom crank pulley bolts in stock!
Old Sep 25, 2014 | 11:17 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We have boxes and boxes of these in stock , for anyone wanting to upgrade from the stock stretch bolt to a much higher quality fastener. ARP bolts will greatly increase your clamping pressure on your big crank pulley. These custom ARP high quality performance bolts, can be torqued to 250 ft lbs, if you want to muscle up on some of these PM me or Shardul.
70.00 each and they are re-usable.
Factory stretch to yield, one time use on the left and ARP performance bolt on the right.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 26, 2014 | 08:44 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
very good replacement bolt against the OEM TTY . I've installed 15 of these bolts , with 100% satisfaction. Cheers _PTEngineering
Old Sep 26, 2014 | 09:20 AM
2000UZJ's Avatar
E55
I'll be PM'ing you when my new pulley is complete. Should be a couple of weeks. Make sure you don't sell out!
Old Sep 26, 2014 | 04:01 PM
PLATINUM SPONSOR
2003 CL55
No problem and will make sure you are covered.
__________________
www.ultimatepd.com
Old Sep 26, 2014 | 04:47 PM
Denroll's Avatar
'06 E55
They should make one for the supercharger pulley. I need one of those.
Old Sep 27, 2014 | 06:31 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
With this bolt do you think there is any need to pin an aftermarket pulley?
Old Oct 14, 2018 | 09:30 AM
macarena78's Avatar
mercedes e55 amg w211
I want one arp crankshaft bolt for my bigger crank pulley in the e55 amg
still one for sale?
Old Oct 14, 2018 | 09:31 PM
SICAMG's Avatar
2005 e55 AMG
I think Shardul has them. Send him a PM.
Old Oct 15, 2018 | 09:51 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Thanks SICAMG
Yes we have them in stock.
Old Oct 15, 2018 | 05:22 PM
SICAMG's Avatar
2005 e55 AMG
Cost?? I forgot what you told me a while back.....may need one instead of the factory bolt.
