BIP (Great as Always) and Weistec (Great Product)
Old Nov 20, 2014 | 03:45 PM
blackbenzz's Avatar
haters crazy
Originally Posted by jcjmw
Yes, I have their CAI. I will install it this weekend. As for pulley, I reinstalled the OEM CP. I dont know the size of the weistec pulley. It is whatever they gave me to match the OEM CP.
I am going to also install meth. Do you have meth? If you do, can you post pics of how you did the install of the nozzles and how is it triggered?
It should have a number engraved on the pulley.
Yes I have meth injection. PM me your cell number and I can text you pics. I should have some on my phone
Old Nov 26, 2014 | 06:09 PM
jcjmw's Avatar
2005 E55 Wagon
This car is a monster! I think I found another way to help lower cruising IATs, that could apply to OEM SC as well. I will know more later.
As for service and response from Weistec, they have been VERY responsive to me and addressed something that was important to me (At 1pm on day before thanksgiving) within 5 mins of leaving a message.
They even encouraged me to visit them when I will be in CA in December.
Great product and very responsive to my follow ups and questions. Thanks Weistec.
Old Nov 27, 2014 | 12:00 PM
Denroll's Avatar
'06 E55
Oh you tease.
Does it involve moving the intercooler from the hottest part of the engine?
Old Apr 23, 2015 | 03:25 PM
jcjmw's Avatar
2005 E55 Wagon
I thought I would share and post my dyno sheet. With Weistecs 65mm pulley, I should be at 13psi. But, I am actually running max boost of 10 psi. The lower psi, I am assuming, is due to the ported heads (thanks Shardul). At 10 psi, I am at 550ish rhwp. I realize there are cars out there running higher hp and tq. But, I think 550ish rwhp and 500ish rwtq is pretty good at 10psi. I also like the AF ratio on 91 octane.
Attached Thumbnails BIP (Great as Always) and Weistec (Great Product)-10psi-weistec-e55.jpg
Old Apr 23, 2015 | 03:38 PM
blackbenzz's Avatar
haters crazy
Good to see you're happy with the car. How much did you gain with the heads? It looks like your power is falling off at high rpms.
Old Apr 23, 2015 | 04:34 PM
Denroll's Avatar
'06 E55
A 4,000 RPM spread where that thing is over 450wtq... that's badass. How are IATs looking with that conservative level of boost?
Old Apr 23, 2015 | 05:27 PM
  #32
lm7's Avatar
lm7
2003 E55
Any more info on cooling solutions? Nice numbers!
Old Apr 23, 2015 | 05:53 PM
  #33
99lightning's Avatar
99 ford lightning
be nice to see the rise in air charge temp during the run thanks for posting since we do not hear much about these
Old Apr 24, 2015 | 11:17 PM
  #34
jcjmw's Avatar
2005 E55 Wagon
I wish I knew. All I do know is that after the heads were installed, before the Weistec, my boost dropped but it felt stronger. But, I don't remember how much because my Aeroforce kept breaking. I am also assuming the fall off is due to increasing IATs(?). I also noticed the air filter is collapsed or shows sign of collapsing(?). I am trying to see if I can fit a bigger filter.
125-130sih...but I will post more data once I get a chance to really find out more. Recovery is extremely quick.
I have aerogel pyro between engine valley and sc. It helps with heat from engine valley but not the heat from the sc itself. I have the KC. I will install meth down the road.
Old Apr 25, 2015 | 12:17 AM
  #35
jcjmw's Avatar
2005 E55 Wagon
Ok, let me see what I can do.
Old Apr 25, 2015 | 07:28 PM
  #36
Weistec's Avatar
Former Vendor of MBWorld
Weistec
Here is a quick and dirty datalog from jcjmw's car when it was dyno tuned by us earlier this month. Ambient Temps that day were 70 degrees F.
Red line is spark (ignition timing).
Green line is IAT (Intake Air Temperature after the compressor)
Blue line is TP (Throttle Percentage)
Modifications are important to know as well on the car to gauge how well the systems are working.
jcjmw's E55 had the following:
-Weistec M113K Supercharger System w/ Cold Air Intake Option
-65mm Upper Pulley, Stock Lower (12-13 psi max is what we recorded at sea level with this car)
-High Flow Exhaust
-Killer Chiller with no heat exchanger
-Custom Trunk Ice Tank
-Ported Heads
-Additional heat shrouding on the supercharger system (aerogel pyro)
The M113K engine has a soft rev limit at 6500 RPM. Past this, it will slowly close the throttle body until it hits the set rev limit just under 7000 RPM. This is done mainly to give the car a much smoother shift. We can change this but TCU tuning is required. It does get a bit risky as well to start making power past 6500 RPM because factory rod bolts will start to see fatigue at this speed.
The drop you are seeing is the throttle body closing. IAT's although rising, maintain cool temps throughout the run. We hope this helps.
Weistec Engineering
Old Apr 25, 2015 | 08:55 PM
  #37
jcjmw's Avatar
2005 E55 Wagon
-High Flow Exhaust
-Ported Heads
Weistec Engineering
Thanks for the info!!!!
But, why am I reading 10psi in boost w my gauges in Vegas?
Old May 24, 2015 | 08:30 AM
  #38
jcjmw's Avatar
2005 E55 Wagon
I thought I would report back at the 6 month mark. All is good. Car running great, no issues and no cels. My wagon is my daily driver so I put a lot of miles on it. MPG has been 20-22 mpg on th highway 16 mpg city.
I did have to replace my oil level sensor and that 13 pin transmission plug (all very easy to do). I also caught some kids with a screwdriver trying to steal my weistec trunk badge! Other then that all good and planning next mod.
Old May 24, 2015 | 06:15 PM
  #39
Denroll's Avatar
'06 E55
Please, post a link to their obituaries.
Old May 25, 2015 | 12:11 AM
  #40
jcjmw's Avatar
2005 E55 Wagon
Lol! They ran pretty fast and I was standing there trying to figure out why did they not just buy one... Oh well.
