Lengh for belt BELT WRAP KIT
Old Oct 3, 2014 | 03:47 PM
E55GHi5's Avatar
E55 W211
hi,
can someone tell me the lengh for the belt for a belt wrap kit.
Stock crank pulley and smaller sc pulley.
My belt wracked on the highway :-(
Thanks a lot.
Greetings from Germany
Patrick
Old Oct 3, 2014 | 04:02 PM
hayseed's Avatar
04 e55
just installed one
gates k080530
Old Feb 25, 2015 | 05:06 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Hast du schon was rausgefunden Patrick? Länge?
Und Länge mit 77mm FSP? Bei uns steht ja als Produktnummer meist die Länge in mm da.
805mm kann es ja nicht sein oder?
Old Feb 25, 2015 | 05:25 PM
SPatykAMG's Avatar
W211 E55
Originally Posted by hayseed
just installed one
gates k080530
This is the correct size for your setup
Old Feb 25, 2015 | 05:29 PM
Crissus's Avatar
The Problem is... we are in germany.. we can not find this belt here.
Our belts by Gates, Contitech, Dayco, etc are numbered by their length in mm.
So the stock Belt without Beltwrap Kit is:
GATES 8PK1289ES
"Gates" is the manufacturer, "8" is the amount of "ribs", "PK" is the type/material/etc, and "1289" is the length in mm.
So we need the length to find the fitting one according to our in germany used product-code.
EDIT: Did find it: http://www.gatespowerpro.com/Comerge...ryName=K080530
Its 1345mm
Old Feb 25, 2015 | 05:33 PM
SPatykAMG's Avatar
W211 E55
Ok that makes sense. This link should give you all the details
Old Feb 25, 2015 | 05:39 PM
Crissus's Avatar
Beat you by 1 minute^^
Any idea for the type for a fitting belt with 77mm FSP AND Belt-wrap-kit
Old Feb 25, 2015 | 05:56 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
525 or 530
Old Feb 25, 2015 | 06:21 PM
Crissus's Avatar
So to summarize:
Stock Crank pulley + smaller clutched SC Pulley + Belt-Wrap-Kit == gates k080530 (1345mm)
Stock Crank pulley + 77mm FSP SC Pulley + Belt-Wrap-Kit == gates k080530 (1345mm) or k080525 (1336mm)
Now what i would like to know as well is:
Stock Crank pulley + stock SC Pulley + Belt-Wrap-Kit == ???
Stock Crank pulley + 77mm FSP SC Pulley == ???
