issues again ..noise on engine
Old Oct 5, 2014 | 12:32 PM
E55amgsd's Avatar
05 e55 amg
I have this churp noise coming from engin dont know if its from sc or pulley or what :/ ?? Can you guys watch the bideo amd let me know if this has happened to any of you ?http://m.youtube.com/watch?v=zUo0F9NtOe0
Old Oct 5, 2014 | 12:33 PM
E55amgsd's Avatar
05 e55 amg
Old Oct 5, 2014 | 12:39 PM
E55amgsd's Avatar
05 e55 amg
Sorry guys. Forgot to mention that it goes away after driving the car for couple of minites. It only happens when the car its cold or when I step on the car
Old Oct 5, 2014 | 01:34 PM
2000UZJ's Avatar
E55
Remove the supercharger belt and see if the sound stays. If it goes away I would start spinning the pulleys and feeling any inconsistencies with the bearings.
Old Oct 5, 2014 | 01:44 PM
Hulk's Avatar
A Merc
^^^^this
Old Oct 5, 2014 | 02:36 PM
E55amgsd's Avatar
05 e55 amg
Once I remove the belt I can still turn on the car is that safe ?
Old Oct 5, 2014 | 02:52 PM
Hulk's Avatar
A Merc
Yes take off only the sc belt
Old Oct 5, 2014 | 02:55 PM
E55amgsd's Avatar
05 e55 amg
Ok will do ..form your knowledge what do you it could be a bearing ? Or a belt
Old Oct 5, 2014 | 03:06 PM
2000UZJ's Avatar
E55
It sounds like a pulley. You can run the engine safely without the supercharger belt. I would do a cold start and let it idle for a minute or so. Inspecting hot pulleys is not fun. My guess is a supercharger pulley bearing is dry or worn out. OEM ones are not the best. I would reccomend the ASP idler set.
The supercharger is not always engages. If the chirp is only happening when yu step on it, that means it's a pulley.
Old Oct 5, 2014 | 03:08 PM
E55amgsd's Avatar
05 e55 amg
Actually thats a eurocharged 84mm pulley ..I just got this pulley like 2 months ago
Old Oct 5, 2014 | 03:22 PM
Hulk's Avatar
A Merc
I doubt the bearing on the sc pulley after 2 months
Old Oct 5, 2014 | 03:24 PM
E55amgsd's Avatar
05 e55 amg
Maybe a belt because I just checked it and it has minimal shred on it like lil bit ??
Old Oct 5, 2014 | 03:31 PM
Hulk's Avatar
A Merc
That's not a noise made by a belt
Let the car get cold then restart without the belt, if the noise is still there then it's on the aux belt side
Old Oct 5, 2014 | 03:34 PM
E55amgsd's Avatar
05 e55 amg
What is the aux belt side how is that fixable bro. ?
Old Oct 5, 2014 | 03:40 PM
Hulk's Avatar
A Merc
Sorry I said aux I should have said accessory
When I had that sound it ended up being the accessory belt tensioner
Make your car get cold(over night) and start it without the sc belt and let's see
Old Oct 5, 2014 | 03:44 PM
E55amgsd's Avatar
05 e55 amg
Ok so if I start it with out the sc belt I shouldent hear that noise or what should happen when I start it cold and without the belt ? What am I looking for at that moment
Old Oct 5, 2014 | 04:09 PM
Hulk's Avatar
A Merc
With the car cold, if you start it and the sound is no longer there then it's the sc pulley, or idlers, if the sound is still there most likely the accessory tensioner pulley
Old Oct 6, 2014 | 09:00 AM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Hulk is right.
We can make this simple. On supercharged cars, you should consider failing pulleys like oil changes and brakes. It's simply a matter of use. That cold chirp almost always comes down to the tensioner and idler pulleys. If your car has never had them done, I would replace all of them at this stage in the game. You can do them one at a time, but that just wastes time and money. Make sure it's not your crank pulley (MB term Harmonic Balancer). When those start to wobble, belts rub, causing the cold chirp.
The chirp when you hit the gas is likely a separate noise. My guess is you need tensioner and idler pulleys for the cold start noise, and a supercharger bearing for the other chirp. I've heard Eurocharged dealers complain about their pulleys, so I wouldn't rule that out. Sorry. But the procedure Hulk describes is the way to go about it.
I've had all those symptoms (except the supercharger chirp) on mine, and that's how I've always seen my mechanics get to the bottom of it. Remove this belt (supercharger) and that belt (accessory drive) to see if the noise remains, and that's how you isolate the pulleys. Good luck.
maw
Old Oct 6, 2014 | 09:07 AM
maw1124's Avatar
There's an idler pulley down near the ABC pump... Driver's side of the fans, midway up the front fascia. It's hidden from top view, which is why you can hear it but not see it. You can find pictures of the engine on the web or on this site, if you haven't already.
Cheers,
maw
