George's fixed pulley on the dyno.
If I do get this -my car is in similar status minus kleeman. So minimally modded.
First people thought it was due to modified throttle body but it seems unrelated now.
Thanks again and I hope all this gets sorted out quickly and effectively.
#32
Just a quick update. Got retune from Tony at BIP friday, put about 150 miles and all seems good. I think Tony nailed the tune. Will keep driving and see if anything comes up. May do some street logs this week sometime. Then hit the track.
#34
I'm feeling good about this even more! Getting my extra O2 bung welded in, will be fixed sooner than later
#37
Well up to now the fix pulley seems to be an excellent upgrade. I hit the track this Saturday at Cecil County Dragway great track. I was pleased with the outcome. Here is my time slip.
#41
Is there a clutch on something like a ZR1? We are concerned over air intake temps and how it declutches, but does it also declutch at shifts?
#42
I don't think ZR1 has a clutch, but it's a smaller supercharger I believe. Concern is over air temperatures running too hot, and a lack of a way for for ECU to correct/shutdown with overly hot intake air.
#43
Wow!!! Very impressive! Where the hell is my wideband???? I need a solid pulley!
#45
#47
99 ford lightning
I have a dyno log that has about 4 -7 deg of timing on low act not high. the higher act run has way more timing in it but pulling the normal amount.
