George's fixed pulley on the dyno.
Old Nov 1, 2014 | 05:15 AM
99lightning's Avatar
99 ford lightning
On the dyno last night the fixed pulley car made 497hp and torque was in the 530ish range. Kleemans and fixed pulley bip tune. the car runs great just have to figure one bug out, for some odd reason on the cool down run starting act at 68 deg its pulley tons of timing and actually made 436hp. The second run act started at 91 deg act and made the 497hp. still pulley timing obviously for safety but not like the cool run, no timing in the motor.
Old Nov 1, 2014 | 09:37 AM
lm7's Avatar
lm7
2003 E55
Any before #s?
Old Nov 1, 2014 | 09:43 AM
99 ford lightning
yea I have to grab them all from the shop computer. It picked up big time though feels mean as hell just need to get timing sorted out.
Old Nov 1, 2014 | 10:35 AM
viper04's Avatar
Nice! thanks for the up dates. What are is mods? and any drivebility issues.
Old Nov 1, 2014 | 12:07 PM
99 ford lightning
drives perect.
Old Nov 1, 2014 | 12:30 PM
chawkins2001's Avatar
2006 E55 AMG
told u Tony's timing was conservative
he will fix it Monday homey.
Old Nov 1, 2014 | 05:46 PM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
last nights dyno
Heres the dyno graf
Old Nov 1, 2014 | 07:44 PM
Guran's Avatar
SLK32 AMG
A fixed Pulley will allways get you higher temp. And a bad dyno. You dont want the SuperCharger to run when you dont need the SuperCharger power.
Get a small S/C pulley with a magnet. The best is to install a switch, where you can control when you want to use your S/C. Now you have really low IAT. And now we are talking horsepower.Nothing new under the Sun
Old Nov 2, 2014 | 10:17 AM
kponti's Avatar
E63
So about 63rwhp gain with the 77mm pulley, similar gains as the 80mm graph from BIP.
When you say kleemann car, what other mods does the car have?
Old Nov 2, 2014 | 10:30 AM
Hulk's Avatar
A Merc
I think he meant kleeman headers
Old Nov 2, 2014 | 10:59 AM
kponti's Avatar
E63
So kleemann headers and 77mm solid pulley netted near 500rwhp ... not bad at all. Any other mods takes you over 500rwhp (also known as my goal).
Any cooling mods?
Old Nov 2, 2014 | 11:13 AM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
EUROCHARGE HE, split cooling,
Old Nov 2, 2014 | 11:15 AM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Hit a bump on the road again .. limp mode code p0106.
Old Nov 2, 2014 | 11:42 AM
kponti's Avatar
E63
Did you check your rubber y pipe to throttle body? How about the hose from the rubber y to crankcase?
Old Nov 2, 2014 | 11:46 AM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Checked all of that, everything is tight and solid.
Old Nov 2, 2014 | 11:48 AM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Wiil a recalibration of the stock throttle body help this?
Old Nov 4, 2014 | 10:01 PM
viper04's Avatar
Any updates with resolving the code?
Old Nov 5, 2014 | 12:21 AM
Denroll's Avatar
'06 E55
The MAP sensor code. Mine is gone, finally. I switched to the newest version of the MAP sensor and then Jerry was able to tune it out.
Old Nov 5, 2014 | 08:25 AM
ghlainez's Avatar
Veteran: Army
06 E55 AMG
Still trying to figure it out. In the last couple of days its been acting up. Just yesterday I pull out of my drive way it instantly goes into limp mode so I decided to park it back in the garage and deal with it after work. Once I got home later that day I start it up pull out of my drive way no limp mode till I drive it around for a bit. Whats the deal? Heading to my buddys tonight with star and try and get to the bottom of it. I keep getting codes like P0105 and P0106.
Old Nov 5, 2014 | 10:57 AM
viper04's Avatar
Thanks for the updates. I have one waiting to install.
Old Nov 5, 2014 | 12:56 PM
d613's Avatar
Supra94,Evo8,335i(daily)
So it seems like this just comes down to a tuning issue.
Denroll has it fixed with jerrys Eurocharged tune.
And your trying to get the fix with BIP tune.
Old Nov 5, 2014 | 03:50 PM
kponti's Avatar
E63
So BIP has that code fixed with the clutched tune and Eurocharged has it fixed with a new MAP sensor and the FSP tune
Old Nov 5, 2014 | 03:55 PM
Hulk's Avatar
A Merc
Old Nov 5, 2014 | 04:23 PM
Denroll's Avatar
'06 E55
When it goes into what I call "hiccup mode", you can turn the car off and back on and it will be back to normal. It's a very frustrating thing and it seems the fix has been different for several different cars. After a while, you can figure out what combinations of throttle and load triggers the hiccup, then drive around it. It really sucks. I also found that it triggers differently under different temp/altitudes.
Jerry had a fix a few months ago in his tune that worked in every car until mine. I was still getting it. I tried multiple MAP sensors, checked for leaks, etc. Finally, he created a new tune for me to test out and it has been doing great. One or two more flashes and I will have my AFRs looking perfect, then I will get to the track to test it out.
Old Nov 5, 2014 | 07:13 PM
viper04's Avatar
Denroll
Nice! please let me know when you have the A/R and tune, down. I will contact Jerry then for the same/similar file. Also on the map sensor can it be pick up at Auto Zone/Advance, ect. or dealer only.Thanks.
