Hello everyone, I have a question about wheels, I am wondering if these wheels would fit on my e55, I looked all over the forum and could not find anything. These wheels are the genuine sl65 wheels however they are the 10 inch versions with different offset.
Wheel specs:
Fronts are 8.5x19" ET 25 with 255/35/19 tires
and the rears are 10x19" ET 28 with 285/30/19
I assume these wheels will fit but will I have to shrink to 275 rears?
Please help!!
Wheel specs:
Please help!!
Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
Wheels and tire combo will work and look real good
Are you sure they would fit? It says in the tire/offset calculator that the tire would be sticking out 21mm more then stock, I have heard people on the forums with the 9.5" sl65 wheels that they are rubbing with 285s on the back with a 31 offset that = only a 17mm more sticking out then stock. so if these tires stick out 21mm more then stock I assume they would rub, I tried 275 on the 10" rims on the calculator and it said they would only stick out 15mm. Also would the front wheels rub when u steer the wheels, the tire calculator said they will stick out 10mm more to the fenders then stock.
Anyways here is a screenshot of both the front and rear wheels that I am looking to buy in the tire/offset calculator, I put stock rims in first one then the sl65 wheels in the second one, Package 2= sl65 rims .
