Signs of a bad torque converter
if I engage the gears it immediately shuts down, when engage and disengage 2-3 times it works ok
I have done oil and filter change 2 times just to flush it and replace again
I have changed the radiator because were sign of water on the tranny
I have changed the solenoid valve because it had an error and also the battery because it said "valve loss of voltage" when cold started
now I am having the same problem but slighter better, it tents to shut down but in 1-2 seconds it gain power again
do you think its the TC ?
I inserted some videos just for better info
https://mbworld.org/forums/e-class-w...ml#post7134800
hopefully it is set now
I have been reading through this post with great interest. Some great knowledge shared. I have a 2004 s320 W220 and I think my TC may have a problem but not sure. My symptoms are:
1. Going down hill at low speed 15-20 mph revs stay up about 1.8k and doesn't change up a gear. If I hit the gear lever to change up then changes gear and revs drop
2. Getting some shuddering under acceleration and braking (not sure if braking is pad issue am going to check this week cheap pads!?)
3. GB oil was changed about year ago and done about 15k since. At the time I was not aware of the possible TC drain plug so this definitely wasn't done.
So was wondering from the above if this my TC failing or failed or any other thoughts would be appreciated. Thank you.
