Multi-Displacement V8 - No Mercedes V8 has this technology!
Old Jan 6, 2004 | 03:20 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
MDS - Multi Displacement System is coming on the 2005 Chrysler 300C and Dodge Magnum R/T with the 5.7 Liter Hemi V8 engine. The V8 saves fuel by running on 4 cylinders. Only the Mercedes V12 does that - runs on 6 cylinders. The cars go on sale in April and May 2004.
This released by Daimler-Chrysler on 5 Jan 2004:
"Chrysler Group Multi-Displacement System will be First Cylinder Deactivation Sold in North America on Modern, Large-Volume Vehicles
2005 Chrysler 300C and Dodge Magnum RT Will Feature HEMI® Power with Maximum Fuel Economy
Up to 20-Percent Improvement in Fuel Economy
Standard Equipment on Chrysler 300C and Dodge Magnum RT
Uncompromised HEMI® Power
Smoothly Transitions from Eight Cylinders to Four in Just 40 Milliseconds"
Additionally:
"The system deactivates the valve lifters. This keeps the valves in four cylinders closed, and there is no combustion. In addition to stopping combustion, energy is not lost by pumping air through these cylinders.
Customers will experience estimated fuel economy gains of up to 20 percent under various driving conditions, and a projected 10 percent aggregate improvement. Improved fuel economy is realized without any change in customer experience—drivers will receive the benefit without changing their driving habits and without compromising style, comfort or convenience."
Old Jan 6, 2004 | 06:16 PM
WannaBeAMG's Avatar
Re: Multi-Displacement V8 - No Mercedes V8 has this technology!
didnt they eliminate that with the new Twin-Turbo though?
Old Jan 6, 2004 | 06:45 PM
awiner's Avatar
2003 CL55 AMG
Yes, as of 2003, the V12 Mercedes engines no longer have the 6 cylinder cut off.
I know the 2001 - 2002 Mercedes V12's had the cylinder cut out.
Old Jan 6, 2004 | 09:42 PM
jl88's Avatar
Dude, last time when DC tried this, they ran into problems. The 2001-2002 S/CL600's were plagued with problems because of this "feature".. and to top it off, the mileage STILL sucked
Old Jan 6, 2004 | 10:06 PM
E55AMG99's Avatar
1951 Caterpiller D6
How does keeping the valves closed work? Wouldn't the piston moving down the cylinder create a ton of suction? Wouldn't this creat drag? Could this suction be great enough to unseat the valve?
No manufacturer has had any luck with this idea. GM spent $$ settling the lawsuit the owners of the 8-6-4 engines brought and MB drops it after only 2 years. I'll pass. Thanks.
Old Jan 6, 2004 | 10:38 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
"How does keeping the valves closed work? Wouldn't the piston moving down the cylinder create a ton of suction? Wouldn't this creat drag? Could this suction be great enough to unseat the valve? "
That's exactly what I was thinking. Have you ever tried to pull a suction against a wall? It doesn't work very well and with the valves closed the engine would in effect be sucking against a wall.
Old Jan 6, 2004 | 10:52 PM
E55AMG99's Avatar
1951 Caterpiller D6
EXACTLY!
Much easier when you remove the spark plugs from an engine and turn it over. If they opened the intake valves however, they'd have to open the exhaust valves EARLY to avoid compression friction. That is pretty hard to do on a gas engine with a mechanical camshaft and valve system.
Old Jan 7, 2004 | 12:14 AM
cschow's Avatar
2006 Corvette Coupe
Arg, schemes like this make me cringe.
There's no way you can assure me that you don't loose peak performance by running half the engine when lightly loaded (i.e., most of the time). The only multi-displacement technology that ever made sense to me was on Caddy's Northstar system, which disabled half the cylinders only when all the coolant leaked out to give you a safe driving window to get to a service station! Lets hope this scheme fails terribly, or at the very least, that the consumer can hack together some sort of all-cylinders-on switch.
Old Jan 9, 2004 | 04:13 PM
AKRY's Avatar
Actually it's not true..... W220 S-Class does have cylinder cut-out on both S500 and S600... However, only European S500 can be had w/cylinder cut-out....
Old Jan 9, 2004 | 11:27 PM
E55AMG99's Avatar
1951 Caterpiller D6
Not sure where you got your info but V-8's never had it anywhere and V-12 dropped it in 2003 everywhere when they added turbos.
Old Jan 10, 2004 | 02:25 AM
AKRY's Avatar
MB doesn't offer Cylinder Cut-Off on S500 because the cost of adding it is equal or greater than Gas Gazzling Tax... Or at least that's MB's excuse for excluding this technology for NA market... Anyways....
http://www.findarticles.com/cf_dls/m.../article.jhtml
Mercedes springs a cylinder cut-out system for its new 5.OL V-8, while Honda debuts a VTEC for engines with bucket-type tappets.
MERCEDES' CYLINDER CUT-OUT
Nearly 20 years after Cadillac shattered its own reputation with its infamous V8-6-4 variable-displacement V-8, Mercedes-Benz becomes the first European automaker to offer a cylinder cut-out system. It's aimed at boosting fuel economy on the company's new 5.0L sohc, 24-valve V-8. Optional on the 1999 S-Class (a 4,139-pound sedan) the system shuts off four cylinders by deactivating their valves.
The system retains the base engine's double-rockershaft design but replaces its one-piece rockers with a pair of unique arms. One arm follows the cam lobe for valve opening/closing, the other controls the valves' deactivation. In full V-8 mode, hydraulic pressure forces a tiny piston to lock both arms together. In deactivated 4-cylinder mode, electromagnetic shift valves force the locking pistons against return springs, shutting the valves (both intake and exhaust side) and thus the cylinder.
Based on an engine load map, the ECU staggers cylinder deactivation in each cylinder bank -- number two and three on the right, five and eight on the left. It works automatically between 1,000 rpm and 3,500 rpm in third through fifth gears. Valve reactivation happens when the hydraulic pressure releases the little pistons, which locks up both arms again. To keep the walls of the deactivated cylinders warm during cut-out, the system closes the exhaust valves immediately after the power stroke. They open first during reactivation.
The system apparently robs the base V-8 of about seven horsepower -- 299 hp versus 306 hp. But fuel efficiency (on the new European driving cycle) is claimed to increase 7%. And at a steady 56 mph, it's improved by 15%. Sport-utility vehicle planners, take note.
Also here....
http://autozine.kyul.net/html/Mercedes4.htm
CCS cylinder cutoff for 5.0 V8 : to save fuel when the engine is running at light load, 4 of the cylinders will be cut off, others' ignition and injection timing will be adjusted to keep the engine running. Claimed to save 7-15% fuel. This is not a new concept, GM and Mitsubishi had tried it in before. After all, is it really important ? You pay the price of a V8 for a 4-cylinder ?
I am not sure if they still offering CCS for W220... But I am pretty sure they had CCS for both S500 and S600 back then.... Had a chance to look through one of the European Brochure they used in Taiwan... It was an option for S500.....
Old Jan 10, 2004 | 02:40 AM
E55AMG99's Avatar
1951 Caterpiller D6
Thanks for the info. I didn't know they had it as an option on the V-8. I wonder how many they sold.
Old Jan 10, 2004 | 07:57 AM
EDWARD CONROY's Avatar
2004 E55
More neat info from Kev. This is the kind of technology I wouldn't touch until it's perfected, but I've gotten enough fill ups under my belt for my thirsty beast to appreciate what they're going for.
Old Jun 19, 2019 | 08:21 PM
Chuck Hall's Avatar
W220
Probably got that info from the owners manual, or the video MB made showing the features, or dash indicator showing when it's in that mode.
Old Jun 19, 2019 | 08:49 PM
BlownV8's Avatar
15+ year old bump. Bravo!
Old Jun 19, 2019 | 09:19 PM
Chuck Hall's Avatar
W220
Ditto. I thought technical info never expires, but for you that only applies to unnecessary insults.
Old Jun 19, 2019 | 10:45 PM
BlownV8's Avatar
That wasn't an insult. Just never seen a 15+ year bump on this forum. Kind of impressed actually.
