Leaving car overnight in Sport 1&2 QUESTIONS!
Old Dec 19, 2014 | 02:14 PM
06E55BEAST's Avatar
2006 E55
Does leaving the car in sport mode 1 or 2 overnight or extended periods of time cause any compression leaks or pressure on the airmatic struts?
Old Dec 19, 2014 | 02:26 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
No problems. Mine has been in sport 2 since the day I got it.
Old Dec 19, 2014 | 02:42 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
no problem whatsoever
mine has been in sport 2 for last 7 years
Old Dec 19, 2014 | 02:50 PM
berti_00's Avatar
2016 Cls63s AMG
I have never taken it off sport 2 ever since ive owned it... Only when I raise it to let my wife drive it and me being in it too
Old Dec 19, 2014 | 04:05 PM
02C32guy's Avatar
2005 E55
Must be nice to live in an area without potholes...
Old Dec 19, 2014 | 07:56 PM
ilko's Avatar
E63 Kombi
Same here.
Doesn't the Sport mode stiffen the shocks? I don't think it is air-spring related.
Old Dec 19, 2014 | 08:13 PM
SL55_Forever's Avatar
3-pointed star
Is it the same for ABC sport I wonder...?
Old Dec 21, 2014 | 12:04 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I live in Boston... We produce potholes by the hour... My car lives in sport 2 unless I go to comfort and raise the car for a steep incline. Should have no worries leaving it over night
Old Dec 21, 2014 | 11:24 AM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
I use sport one no issues. From what I understand sport one and two both lower the vehicle the same amount but sport two increases shock firmness a bit over sport one.
Old Dec 21, 2014 | 11:58 AM
RikTT's Avatar
A bunch of TT's
Auto lowering is 10mm for S1 & 15mm for S2
Old Dec 21, 2014 | 03:43 PM
Max.H's Avatar
E55
My car is lowered with STAR. But,the streets can be bad, I leave my car in raised mode. It lives in raised mode for past 2 years +
Old Dec 22, 2014 | 01:20 AM
Elhonaz's Avatar
W211 E55 2003
Originally Posted by ilko
Same here.
S1 and S2 both are lower than comfort -> less air in the strutt makes it stiffer. It however does stiffen the shoks also, electrically through the dampening unit that is located on the strutt it self
http://bayhas.com/mercedes/w211/contents/sas/sas.htm
Old Dec 23, 2014 | 09:36 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I believe Sport I also adjusts itself. If the road is too bumpy, the suspension will soften up. If you go hard into a turn, it will stiffen up.
Sport II stays firm no matter what.
Comfort stays soft no matter what, but lowers at freeway speed.
Old Dec 23, 2014 | 12:59 PM
agregory23's Avatar
E63S
I have noticed when I get out of the car and lock it, the air releases out the front and you can see it lower itself. I haven't checked to see that it does that on all settings but I am pretty sure it does. What that tells me is it doesn't matter where you leave it, the car is going to lower itself when its parked.
