stock air box vs fabbed up cold air kit
Old Jan 1, 2015 | 11:04 AM
99lightning's Avatar
99 ford lightning
so I had this made last year never did a thing with it its pretty ****ty but wanted to try it here is what I found. I never see usefull data so here is some. runs in m mode 3rd gear pulle starting around 2800rpm
stock act 59f-108f-49 deg rise cold air kit. 55f-104f= 49 deg rise in temp.
stock air box boost. 3300rpm 11.1lbs 4500rpm 12psi 5700rpm 11.7lbs 6200rpms 11.7 pounds.
cold air kit. 3300rpm 9.5psi 4800rpm12.3psi 5700rpm 12psi 6200rpm 11.3psi. so my findings is it does flow more for a hack kit and crummy filters. it lose boost on the bottom prob due to rush of air or small filters and stock throttle body. but it did pick boost up in the mid range. part throttle you can feel the difference. im leaving stock box on for now. just some info for you kids.
Attached Thumbnails stock air box vs fabbed up cold air kit-cheap-cold-air-kit-55.jpg
Old Jan 1, 2015 | 11:14 AM
Worth the wait's Avatar
2006 E55
Interesting...thanks!
I always dream of a ram air intake, with nasa ducts cut into the hood directly feeding a Renntech air box Lots of issues to work out with that, but I think it would be bad azz.
Old Jan 1, 2015 | 07:15 PM
viper04's Avatar
Nice! thanks for posting.
Old Jan 1, 2015 | 07:35 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
thanks for posting
Old Jan 1, 2015 | 07:52 PM
chawkins2001's Avatar
2006 E55 AMG
good info bro, just goes to show how good our stockers are.
Old Jan 1, 2015 | 08:32 PM
Denroll's Avatar
'06 E55
I made my own intake, too. I wish I would have datalogged a before and after run. In addition to the filters and pipes, I made this huge Y-pipe and modified and bored the inlet to work with the 90mm throttle body. It confirmed my feeling that the Y-pipe and inlet is definitely a choke point with the bigger TB. The butt dyno tells me it picked up a lot of power. As a bonus, the supercharger is much more audible now. Pics of the setup and a vid of the sound:
Old Jan 1, 2015 | 10:05 PM
AMG Boost's Avatar
2010 C63 P30
E55 AMG Supercharger whine - YouTube
Sounds great!
Man really love the E55.
Old Jan 2, 2015 | 12:51 AM
03svtkiller's Avatar
2011 Cadillac CTS-V
Hulksters e55 whine I think he's stock
Intake too lol
Old Jan 2, 2015 | 01:37 AM
Sk9106's Avatar
I own a 2006 E55 AMG parts list longtube headers e63 exhaust ftpheat exchanger and a crank p
Denroll how did you make that y-pipe
Old Jan 2, 2015 | 04:53 AM
sexyxe's Avatar
04 E55
Good to see some data. There are a lot of old threads where members talk of getting dyno before and afters, or assessing gear but never do, which is a bummer!
Old Jan 2, 2015 | 04:58 AM
99 ford lightning
I don't think the stock air box is great, Its probably perfectly matched for the throttle body, so adding a bigger cold air kit yea I did pick up boost but if the throttle body can not take it in you wont gain much.
Old Jan 2, 2015 | 09:11 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
This. With a stock 74mm TB the stock box works fine. Just insulate it from heat as much as possible and keep the filters clean. Once you step up to larger TBs it's worth looking at other intakes. I do think it would help to wrap your CAI and throw some better filters on and see what the result is.
I did love the whine of mine when I had the CAI intake on it. My wife told me it sounded like a jet was coming.
Old Jan 2, 2015 | 09:19 AM
Hulk's Avatar
A Merc
The stock intake is good even on bigger tb, bk has a stock intake with 82mm and ran very well with it.
Old Jan 2, 2015 | 10:10 AM
99 ford lightning
I think with stock boost the stock tb and plenum is a restriction. since im 2lbs less of boost on dyno vs street. I mean a cts-v even has a 87mm tb from factory. Every supercharged car I touched picked up hp from a tb. My 390hp saleen ran a 75mm tb which picked up 15hp going from a 65mm. Since I seen a boost increase with the fabbed up cold air kit pretty sure it can not see its full potential due to the bottle neck of tb and plenum. air charge temps were the same with both.
Old Jan 2, 2015 | 10:35 AM
Hulk's Avatar
A Merc
Not talking about the tb here, talking about the intake and the 82mm still does very well with the stock intake
Old Jan 2, 2015 | 01:37 PM
Denroll's Avatar
'06 E55
Two 90 degree silicone elbows, cut and bonded together.
Old Jan 2, 2015 | 01:41 PM
LNDMISSL's Avatar
E55 W211, G55 W463, 2010 GT500, 2008 S4 Cab (Wife), LR4
Good info, thanks! Here in the burbs of Buffalo there is not much traffic and the air is cold.
My friend made me this:
I made a few of these logo's for him:
Old Jan 2, 2015 | 01:47 PM
Denroll's Avatar
'06 E55
Damn, those are some monster pipes. If you have access to a machine shop, have the supercharger inlet modified. All that air has to go through that one tiny hole.
Old Jan 2, 2015 | 01:54 PM
Denroll's Avatar
'06 E55
Here's another shot of my Y-pipe compared with the bigger OEM pipe. I'm looking for the pics of the modified inlet.
Old Jan 2, 2015 | 04:29 PM
99 ford lightning
nice intake man but as I shown you should log it because although I gained boost in spots I also lost some so you can be hurting your performance.
Old Jan 2, 2015 | 04:46 PM
Denroll's Avatar
'06 E55
Yeah, true. The dyno deep in my B-hole tells me it worked. I had a tiny spot like right after a shift where it felt like it wasn't in the beefy part of the power band. After this work, it's no longer there.
Old Jan 2, 2015 | 04:48 PM
99 ford lightning
no the stock one you should be fine since you have that 90mm on your car.
Old Jan 2, 2015 | 05:08 PM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Thanks for the data, 99L.
D's car sounding great from the front and the rear.
Old Jan 2, 2015 | 05:14 PM
99 ford lightning
the companies that charge 800 bucks for cold air kits should be providing info for us.
Old Jan 3, 2015 | 03:28 PM
boostiality's Avatar
2004 E55
^werd
The local 1/8th mile will be open next Thursday and I will do back to back tests on the stock set up versus the NeedsWings CAI. Stock TB but with 180mm and MBH LTs
