BROKEN SUPERCHARGER PULLEY DESTROYED my car!!!!
#126
I made my own intake with carbonio inlet tubes and custom piping, I can't speak for other companies products. The main purpose of that conversation was to point out how stupid it sounded that an upper pulley only gives 9hp as stated by a forum member...
#128
That can be a he said, she said until that specific setup is dyno proven, I'm not going to argue with that I know its not a crazy HP upgrade. As for financemike claim, sorry I don't believe that. Either something wrong with the pulley or different type of pulley thats very hard to believe that low of numbers doesn't make sense.
#129
2004 E55.98 SS Camaro.Jetta TDI. Expedition
These mods ha e been discussed for weeks at a time over years. No intake is worth 10-15 hp. The stock is that good. This isn't like other cars. You can't swap tubes gain 20. Can't delete cats gain 20. There is plenty of power left in there.I have done a lot of research. I have spent over the last year before I was a member and since I got my car 100's of hrs like 400+. Why? Don't know trying to find what really works. It's interesting to me. The 84mm sc pulley is a baby pulley. Worth 20 hp max. They say it the same as a 168 crank. Not true. As a matter of fact, power/ heat producing I would rank the Kleeman 168 crank pulley the number 1 pulley for the 113k engine. This was an early design and really made the car a legend. That being said a 180 crank will produce more hp but will produce a lot of heat. You can't run the stock cooling, you have to split do a new heatexchanger and do a trunk tank or look into meth or KC. If you don't a smaller pulley will walk u. Guys that have max cooling,injectors tb headers etc run 195mm cranks and more. There is a lot on tap if you can spend the money.
#130
#132
Well ya because they probably spent over 10,000 on mods and decided not to do an intake. I still haven't seen a heavily model vehicle without a custom intake, why wouldn't you is the question?!
#134
Well than let me rephrase, for my likings stock intake is no good, not on a high performance vehicle, but that's just my liking to my style of modifications. To each their own, we can go back and forth about this for years and it's going to get no where. I can only speak truly from my experiences and from working on turbo vehicles for many years, stock intake is garbage. One thing I will say these performance engines had millions of dollars of R&D from mercedes and that's why they are effective, but not as effective as a performance intake. I still go back to my roots.
#135
Now, what's that worth, I have no idea. But there's been a huge gain in the seat of the pants-o-meter.
#137
Please, do you research before sharing incorrect information on the forums...
http://ultimatepd.com/pulleys-mb55sc.html
2003 - 2007 UPD MERCEDES M113K AMG 83MM SUPERCHARGER PULLEY
SKU:MB55SC
Availability: In Stock $595.00
QUICK OVERVIEW
Fits 2003 - 2007 AMG Mercedes 55K Models
Ultimate Performance supercharger pulley upgrade for the AMG 55 Kompressor motor. Our tests show 45- 50 rear wheel hp and torque gains, while maintaining a safe level of boost and supercharger rpm. Pulley upgrade offers excellent driveability and does not adversely affect highway mileage.
SKU:MB55SC
QUICK OVERVIEW
Please do my research before posting? Really? I've contributed to this board much longer than you have.
Here's the deal. All parts and tunes were purchased from Eurocharged, all installations done by RageTek, all dyno runs done on the same dyno during the same two month span with basically the same humidity and temperature. So any variables are out the window.
100% stock motor/tune with a CM30 pump and HE
411whp and 454wtq
ECU Dyno Tune by EC
444whp and 481wtq
added SC Pulley with Box Tune
451whp and 502wtq
added Kleemann headers with Box Tune
478whp and 515wtq
same mods with custom dyno tune
491whp and 525wtq
removed SC pulley with dyno tune
482whp and 510wtq
So there you have it.. I've posted various dyno graphs over the past 4 years to go along with these numbers. I've attended dyno days with some of the nastiest 55k's you'll ever see.
Don't come across like a veteran until you can bring more substance than a copy and paste from a vendors website.
By the way, nice jacket and pants...
#138
411whp and 454wtq
ECU Dyno Tune by EC
444whp and 481wtq
451whp and 502wtq
478whp and 515wtq
491whp and 525wtq
482whp and 510wtq
411whp and 454wtq
ECU Dyno Tune by EC
444whp and 481wtq
451whp and 502wtq
478whp and 515wtq
491whp and 525wtq
482whp and 510wtq
#139
All dynos read differently. That's why I made sure all runs were on the same unit during the same time of the year.
If you search around, "most" sc pulley and tunes will net about 450whp. Sure there might be a single much higher number, but that motor was built on a Wednesday.
#140
Do you have before and afters on the same dyno? All my runs were on the same dynojet.
#142
#143
Right, and also Mustang dynos are more conservative than dynojets. Mustangs measure tq on a force loaded drum, where the dynojets measure tq on a free wheeling lightly loaded drum.
I've been told to get an "approximate" conversation from a Mustang to a dynojet, you can multiple your Mustang number by 1.12 to 1.15 to get the dynojet numbers.
Either way, its just a tool to gauge your progress. Which ever one you have available, stick with it and go from there.
#145
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
411whp and 454wtq
ECU Dyno Tune by EC
444whp and 481wtq
451whp and 502wtq
478whp and 515wtq
491whp and 525wtq
482whp and 510wtq
411whp and 454wtq
ECU Dyno Tune by EC
444whp and 481wtq
451whp and 502wtq
478whp and 515wtq
491whp and 525wtq
482whp and 510wtq
i dynoed 507 whp on that same ragetek dyno w/ 172m crank pulley and headers on a EC dyno day and then 520whp with 180m pulley
#146
There were guys running 12 scratch and even 11.9s stock at PBIR in E55s. The CLS seems to always be a few clicks behind.
#147
'06 E55, '15 Jeep SRT8, '94 Mustang GT
#148
Once again I will add, the dude was sick to his stomach after running an aftermarket supercharger pulley that let go after 2 to 4 years (was on the car before he bought it) causing a couple of thousands in repairs. But loving your car means spending over $2000 on plastic intake tubes with carbon fiber overlay.
Hey 10 year rotary engined veteran, two things:
1. Stock supercharger pulleys also lets go, mine did and shot a bearing out like a bullet toward my radiator, only stopped by the shrouds
2. MB probably spent a 100 times more dollars developing the stock pulley and stock intake than ANY aftermarket parts maker. Have you never wondered why a full aluminum pulley costs less than half of the plastic stock crap?
#150
