AMG55 Scattershield for Supercharger pulley
#152
I expect with the escalating rate of pulley failures that the "test" will happen sooner than anyone would want. Being that the shield comes with a money-back performance guarantee (that has yet to exercised), I can say with confidence that none, so far, has failed to perform as intended.
Cheers,
Chris
Cheers,
Chris
#153
Yes, the scattershields are still available.
The universal version (short post version) is $110
10-12-15 EDIT .... all of the "long post" (NON universal) shields are gone.
there are only universal shields in stock (and production) ... SO, there is no longer a need to determine if you have a long or short post. The current model fits all AMG 55k motors.
Cheers,
Chris
Cheers,
Chris
#154
Hi Chris, we've chatted a few times about shields, I have the same issue as the guy above with one of the two mounting points broken off completely.
Did i read that you have a solution for us one pegged guys?
Thanks,
Ben
Thanks,
Ben
#155
^ it really is amazing what can happen when these belts explode. I had a serpentine belt blow. Not sure if i am using the right term, but I am talking about the main belt not the SC belt. When the belt blew, I was lucky to get the car shutdown fast as the water temp gauge pegged in like one second and the MFD lit up light a Christmas tree. I thought I had avoided any damage only to find out a couple years later that the belt must have taken out a mounting point on the water pump used for the belt wrap kit. I bought the belt wrap kit thinking it would be a simple install only to realize I needed to replace my water pump. I still consider myself lucky.
#156
#158
Yes and no,
I am working on it right now.
Cheers,
Chris
#159
This is what I made for Pearce ("the new guy") today. As you can see, it is NOT a single-post solution. It will work in the case where the forward facing post is compromised (cracked and repaired) but NOT in the case where it is missing altogether. Perhaps I can create a version that will work for you, but not today .... sorry bud
Chris
#161
Chris if you can think of anything that would be fantastic - murphy's law says if I drive without the shield I'll probably regret it - especially with my freshly rebuilt motor! Otherwise I guess I'll have a shield for sale soon...
#164
Yeah I'm in the same boat with the pin completely missing! Ironically enough I was one of the first to buy a shield and even started the original list but havent been able to use it. I've spoken to a couple of people about trying reattach the pin but more difficult than I initially thought. I've even tried to find a broken supercharger just for the front section with the pin but lucked out there also.
I will see what sort of solution I can come up with on this. Don't give up yet.
Chris
#167
Mate you've gone above and beyond with these scatter-shields right from the beginning and are to be commended. If there is anything that can be done I'm sure you'll think of it, though having said that I will certainly understand if it proves too difficult or time consuming.
#168
05 E55, 07 ML500
I just discovered I'm missing a pin as well, the one pointing to the passenger side of the car, (on the right). It looks as if there are threads in the hole for a pin to thread into? Is this available? This is Not the one on the supercharger. Thoughts?
#169
Cheers,
Chris
#170
05 E55, 07 ML500
Chris,
Appears to be 1/2" in depth. Very fine threads. Doesn't really show in pics.. Called ACG their going to look to see if there's an actual part.. Let me know what can be done.. Thx..
#171
It should be a press fit .... although it may have been cast with the 13mm pin in place (and perhaps the pin had ridges to improve retention ... making the casting look lightly threaded on the inside?)
you should be able to press in a 13mm ( x 32mm or so) dowel. Use some green loctite dowel retaining compound (loctite 640 would do it).
Or, you could buy a 1/2 drill bushing (x 1 3/8") and push it in with some good epoxy. here is a mcmaster carr # for one that should work 8491A344
Cheers,
Chris
#172
1 Post
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
I have had mine on now for a few months, with stacked pulleys, my SC turns to the limit, I can't afford not to have this scatter sheild on my car thanks Latemodel for making this,,jim
#173
05 E55, 07 ML500
Cheers,
Chris
Cheers,
Chris
Thank You Sir.. You da man Chris...
