E55 supercharger cuts out
Old Jan 24, 2015 | 07:29 PM
Love amg's Avatar
03 e55
Hi I need help when I step on the car hard from a dig the car will get up to 60 and start loosing power I currently have the Johnson pump could it be the pump going bad? Or could it be the tune.
Old Jan 24, 2015 | 07:44 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
What does it do from a 60mph roll. You may have a belt slipping. Maybe the tensioner pulley
Old Jan 24, 2015 | 07:55 PM
2000UZJ's Avatar
E55
Test the pump first.
Old Jan 24, 2015 | 08:02 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
what happens when you do back to back runs?
Old Jan 24, 2015 | 09:42 PM
Love amg's Avatar
03 e55
Well I just recently had the car in the shop I got the headers , injectors and the arnott coil over kit there was a pulley for the belt wrap kit that was bad but we changed it from a dig I step on it I get the power to like 70 then I could feel the power loss it's like that every run I do .
Old Jan 24, 2015 | 10:01 PM
JoeNobody's Avatar
Mercedes
Johnson pump is worse than stock Bosche 010 pump
Old Jan 24, 2015 | 10:15 PM
2000UZJ's Avatar
E55
How so? I have the CM30 pump on mine. Any recommendations for new pump? Always looking for cooling upgrades. The CM30 has not failed me yet
Old Jan 24, 2015 | 10:51 PM
JoeNobody's Avatar
Mercedes
Search for Lingenfelter article that shows tested flow rates on different pumps. Reliability isn't a problem on most of them, problem is Johnson pump doesn't flow well under high pressure.
Old Jan 24, 2015 | 11:20 PM
Love amg's Avatar
03 e55
I just bought the mezire pump the Johnson pump lasted for more then a year which is still good if the pump is bad or not . Does having the engine bay coolant tank effects the pump?
