Strange Airmatic/Battery..cold weather??
early december I went to a business trip..car was sitting for a week at airport garage and here in MA it was zero degrees every day.. Car has never sat for even 12 hrs without use. when i came back, the rear airmatic was deflated completely both sides. Started car, it raised and drove fine all was normal..even over the following days.
But ive since become a virtual worker, so now i hardly drive and now, with the car sitting in the sub zero temps, the rear always sits down eventually.
When I start the car, it always comes back up, i get no warnings, and it drives normally no issues.
My gut tells me the super cold air is impacting it being retained, but maybe that there is a likely a tiny leak that is not there with warm air. I just find it strange its both struts.....anyone think this is a sign of pending replacement.
Also, Im getting the battery low no convenience now that its been sitting.. but after brief driving all is good.
So Im not rushing out to buy batteries or struts... but I am curious as to the thoughts of the forum members....and if i should start budgeting for some repairs
It's happened for a couple of years now...so you never know, especially with our suspension. The battery issue will go away with a little bit of driving, provided the battery and alternator are healthy.
The E55 seems to use quite a bit of battery power even when it's just sitting parked. Over time, you will end up with a low battery warning..... And it's definitely not good to use the alternator to charge your dead batteries.
-G
Something interesting as well. For two weeks my car was indoors, suspension did not budge....battery ended up dying from non use (extremely poor weather) and the rear dumped by the next day. Don't know if the two issues are related, but seems like an odd coincidence.
Use a spray bottle and soapy water and you will quite possibly find they are still leaking, albeit slower.
Cold weather killed one of my connections. Cost me $4 to fix the leak....
Apparently its not sold as a standalone replacement part and is quite pricey to replace.
for the battery,(trunk) ill probably get a new one since mine is so old... pep boys actually carries a bosch type 49/H8 and with a current promo, is priced all the way down to 130 bucks...that is a total steal
