Pinning crank pulley with good keyway?..safe?
Old Feb 12, 2015 | 09:25 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
has there been any failures on doing this?? I know it has failed with 2 pins after the key way was sheared before hand.
I don't drive my car hard but I want the power if I need/want it. No or little track time.'few pulls in country a month and or road race.
I have considered the sc clutched but I'm looking for more. A pulley is the bread and butter.
I'm thinking an ASP 175 would fit me well. And split cooling.
Please chime in. I'm stock for now
Old Feb 12, 2015 | 10:20 PM
Hulk's Avatar
A Merc
If your keyway is fine you are good to go and pin it, usually guys with bigger than 180 like to pin but for peace of mind , actually any pulley could as long as the keyway is clean and not sheared
Old Feb 12, 2015 | 10:22 PM
chawkins2001's Avatar
2006 E55 AMG
yes, do it for extra insurance. we (bip) developed the first crank pin kit and it is amazing insurance for $250 brotha. I have them in stock.
Old Feb 12, 2015 | 10:46 PM
Ls1toAMG's Avatar
I was thinking one pin would be fine. I'm Leary of doing it myself. On ls1 cars have done torque coverters and and a cam change. I think I can do it..
Do the bits with the kit make it pretty easy or is it a long struggle?
Not sure of a legit place here to do the work.
Old Feb 12, 2015 | 10:51 PM
SPatykAMG's Avatar
W211 E55
I have an ASP180 with the original keyway and the BIP pin kit 180° from the keyway.
Old Feb 12, 2015 | 10:53 PM
SPatykAMG's Avatar
W211 E55
The kit does a good job of it as long as you are careful to not overheat the bit. I tore the entire front end down so I would have a clear view of the crank to make sure it went on perfect.
Old Feb 12, 2015 | 11:05 PM
2000UZJ's Avatar
E55
Pin it. My 180 sheared the keyway. It was a disaster. BIP was able to sand it, sleeve it, pin it, and put a OEM pulley with a crank extension with a new keyway and got it running true. When I say disaster, I mean Jason (the owner) was 80% sure I would need a new motor. He worked on it and became the miracle worker. I wish I had pinned it from the beginning. I run mine pretty hard...
Old Feb 12, 2015 | 11:11 PM
Hulk's Avatar
A Merc
How many miles did you have on it when it sheared your keyway?
Old Feb 12, 2015 | 11:53 PM
lm7's Avatar
lm7
2003 E55
My 180 is pinned on a new clean crank and keyway with a BIP kit and 83mm clutched upper. I spun a keyway on a 175 and 77mm fixed with out a pin kit.
Old Feb 13, 2015 | 12:05 AM
black06c230's Avatar
mgLipGD
My 195 is pinned thanks to BIP. Been about 2 years and 14k miles
Old Feb 13, 2015 | 10:23 AM
SICAMG's Avatar
2005 e55 AMG
Gear change
Anyone know who has the 3.06 gear swap and what the cost is. I can either set the gears up myself or just buy a complete unit and swap it out. What do you guys normally do? Oooops the tune as well will be needed.
Old Feb 13, 2015 | 10:27 AM
SPatykAMG's Avatar
W211 E55
BIP sells the gear kit and might as well do an LSD of your choice while you are in there.
Old Feb 13, 2015 | 02:48 PM
mgLipGD
Yeah BIP and get it done. They have mine right now and should be finishing today actually. Gears were like 350-400. No idea on install exactly as they are also doing an LSD like mentioned above at the same time.
Can't wait as they are also adding a fixed upper pulley. Goes on the dyno on Monday!!
Old Aug 11, 2015 | 04:12 AM
johnny_b's Avatar
04 E55 99 SC400 01 Z06 Corvette
How long is the pin? Im installing mine and afraid it would slide forward and fall out internally?
Old Aug 11, 2015 | 04:48 AM
SPatykAMG's Avatar
W211 E55
If you install it correctly there is absolutely no way I could fall our. I would say it's around 48mm just guessing nor that it matters.
Old Aug 11, 2015 | 05:24 AM
johnny_b's Avatar
Ok thanks for the reply it seems the pin I got is about 10mm I could be wrong, maybe im worried over nothing I will have to check in the morning
