FSP issues, open to suggestions
#152
#153
The hp and especially tq made with a 180 pulley will never be made with a 84mm sc pulley. Go ask any tuner or even go to eurocharged website, I think there's numbers for both.
I have seen it on the dyno also with a car that had a smaller sc pulley and then a 180 crank would come on and make more power.
The 77mm fsp is about the equivalent of the 180 crank
#156
In most cases the 84mm clutched pulley produces 45 rwhp. Not too many get 60 at the wheels. It's a baby pulley. Size wise it really equall to a 166 sc rpm wise. You can take a car that already has a tune and install an 84mm clutched and only expect to gain 20-25 at the wheels. It's been done and disappointed more than a few.
#157
yes i understand that,, my question/misunderstanding is why a 77mm pulley and a 180 crank pulley would not produce the same amount of TQ because the SC would spin at the same rate given everything else the same ?
#161
Unless we have someone with a problem drop their car off to BIP for a few weeks to fix the issues for real, your idea won't work. Note I didn't say EC because EC basically had that with one member one here and so far has been unable to solve the issues however spent countless hours trying
#162
Again it's a custom tune scenario at this point. My cars been ok for over 3000 miles at this point. Temps below freezing, Temps over 80, cold starts, hot starts, no shifting issues, hiccups. Although as I stated before I had every symptom with different versions of the tune before getting a custom one built by Jerry.
I'd say for anyone wanting to run the FSP with more mods then just cooling and FSP you will likely need a custom tune at this point of time. I'm not sure why everyone else besides the OP keeps going on with this speculations on the issues and hoping for a box tune. Work with a tuner and be willing to pay a premium for a custom tune, and they can and will work. Multiple people are running them without issues with custom tunes.
#164
Also your statement "custom tune scenario..." is no different than if I said "Anyone with problems with the FSP should change out their fuel tank, pumps and sending units, that will solve all their problems" (note: I know I have kind of insinuated that, but I will be the first to say I am not sure this holds any merit, however I do know that a fuel additive completely alleviated my symptoms)
#165
https://mbworld.org/forums/w211-amg/...e-shardul.html
#166
UPDATE:
I will no longer really post updates here, I will start a new thread to post my experiences once I get some miles on and tunes redone....ie chronicle my experiences with the FSP
So I picked up my car from the dealer yesterday after having the fuel tank, fuel pumps, sending units replaced. I also had the fuel pressure regulator replaced (fuel damper, whatever else its called).
When I picked up the car, it was already in limp mode. Now the car has been sitting since Tuesday when I got the call that it was ready. So this was a cold start issue.
I was starting to accept that fuel had nothing to do with this FSP issues. But I couldn't pull over to reset ecu and restart the car so I pressed on.
However In less than a mile the car was basically correcting itself and the lean condition was all but gone..... Ok weird
I did eventually pull over and reset ecu as well as restart car. I proceeded to put on 15-20 miles between last night and this morning. No hiccups either, but I will say its a bit too early to make any finalized speculations about hiccups.
This morning I started the car with no delay....No cold start problems today....
Ok so far so good. I am however waiting for a lot more cold start attempts as well as more miles on the freeway at steady speed then suddenly increase speed (usually causes the hiccups) before making any final judgments. But so far so good!
#167
Looking forward to the thread. I'm going to bite the bullet, and get mine ordered today. The 83mm fixed pulley will be my only performance mod, but I do have 550cc injectors. My only issue is that I won't be able to log wideband data, so hopefully they'll be able to extract data from whatever I can log, or maybe I won't have any issues at all? (A man can hope...)
#168
Uraberg I suggest getting a bluetooth OBDII interface and the Torque app for Android if you have not already. If you do not have Android there is one for iPhone but I forget the name of it. This will not give you live readings but they update every few seconds and it's better than nothing.I will be doing the 83mm FSP soon as well.
Also Kponti I looked and could not find your new thread. But I'm guessing since you posted only about an hour and a half ago I'm being an overzealous *******. Carry on
#170
#171
1 Post
sl55 widebody - built viper - ls1 turbo 350z
Any updates? Just installed 77mm eurocharged fsp and tune, will drive ij a few days. No resistor (did not come with one, unsure if its needed at this point)
