Front Suspension parts
2007 E63 AMG
Got alignment done on my 07 @ the dealer and the dealer is saying that I need to replace the lower control arm Part Number: 2113309207 and the bushing Part Number: 2113331114 on both sides online that's over $527 in genuine parts. Has anyone changed out front suspension parts on their E63 and is it worth going for OEM or are generics just as good? Also if generic are as good what brand generic are recommended?
Germany made Lemforder W211 Lower Control Arm Ball Joint OEM Quality $180
Coreteco Mercedes Control Arm Bushing Front Inner up/lo (x2) OEM upper or lower $55
so it seems you can save a little over $100 using vendors that make a lot of parts for our cars - some are OEM too
2007 E63 AMG
Your links are taking me to Amazon and saying will not work on my E63 are these E55 parts? are E55 and E63 front suspension parts different?
Also while a 100 bucks is not bad is it worth going to none Genuine parts?
I was looking on Ebay where you can get a set for $150 for both left and right and bushings for $15 each that's about $180 over $300 cheaper now that seems worth it if those parts are in par with OEM.
Lemforder is as far as I would go, other than Meyle.
They make the parts for MB.
The ebay parts are probably not any of those.
SPONSOR
TO SUIT MERCEDES – VIRTUALLY ALL MODELS 1968 to 2015
(Sedans, Wagons, SUV’s, Commercials).
FOR THE FRONT – THEY ARE ALSO PRECISELY CAMBER AND CASTER ADJUSTABLE!
FOR THE REAR CAMBER (AND EXTRA TOE) ADJUSTABLE.
OEM THERE IS ONLY FRONT AND REAR TOE ADJUSTMENT. . . .
GONE ARE THE DAYS WHEN “FULL FRONT AND REAR WHEEL ALIGNMENT” MEANS JUST THAT.
K-MAC PATENTED DESIGN BUSHINGS HAVE TWICE THE LOAD BEARING AREA AND THE FRONT BUSHINGS ARE 2 AXIS / SELF ALIGNING WITHOUT THE USE OF OIL OR AIR VOIDS. RESULT IS IMPROVED BRAKING, TRACTION AND STEERING RESPONSE.
ONGOING, PRECISE SINGLE WRENCH ADJUSTMENT CAPABILITY TO RESOLVE PREMATURE INNER EDGE TIRE WEAR, STEERING PULL, IMPROVING TRACTION, ALLOWING TO RETURN TO FACTORY SPECS AFTER CURB KNOCK DAMAGE, FITTING WIDE PROFILE TIRES/WHEELS ALTERING HEIGHT OR JUST THE ADVANTAGE TO BE ABLE TO CHANGE SETTINGS FOR “TRACK DAYS”.
YOU FIX IT RIGHT THE 1ST. TIME – NO MORE ONGOING TRIPS TO DEALERS OR ALIGNMENT SHOPS OR CONSTANTLY CHANGING TIRE BRANDS BECAUSE OF ONLY TOE ADJUSTMENT OR THE MINIMAL ADJUSTMENT OFFERED FROM INACCURATE ONE ONLY POSITION OFFSET BOLTS.
All kits come with instructions and bush extraction/insertion tubes (MB World member Heiss Rod has kindly provided step by step picture sequence re front bush installation. See https://mbworld.org/forums/w211-amg/518431-k-mac-bushing-install-guide-w211-airmatic.html )
W210 Front (Camber and Caster) Bushes #502116J $380. (4Matic #502416K $480).
W210 Rear (Camber and Extra Toe) Bushes #502026H $320.
W211 Front (Camber and Caster) Bushes #502216K $480. (4Matic #502416K $480).
W211 Rear (Camber and Extra Toe) Bushes #502526K $480.
( Including airmatic models)
Special promotional price delivery for MB World members USA/CANADA $30 one kit or $40 for front and rear (average delivery time 3 – 4 days). Payment Visa, M/Card or PayPal.
