Sacramento raceway today 4/4 test and tune 12pm-4pm
Old May 10, 2015 | 07:37 AM
Hulk's Avatar
A Merc
That mph is low for those mods. What is the 1/8 time and trap?
Old May 10, 2015 | 08:18 AM
sircl55amg's Avatar
2006 cls 55 amg
Originally Posted by lm7
It was a bit warm. My new wheel setup has it consistently 60ft a 1.6 best time was 11.32@122.
Gonna get a retune, its super lean in first gear and look for some better weather.
getting close !!!
well done !!
Old May 10, 2015 | 08:23 AM
sircl55amg's Avatar
2006 cls 55 amg
the 180/83 combo will give you 16.5-17 psi .... do you run 550cc injectors ?
Old May 10, 2015 | 09:41 AM
Hulk's Avatar
A Merc
Did you see his mod list? It's in the first post.
Old May 10, 2015 | 09:54 AM
sircl55amg's Avatar
2006 cls 55 amg
yep ... no injectors
2003 e55 127K
Weistec 180mm
UPD 83mm upper
Trunk tank/killer chiller/ meth comes in at 90 degree iat
90mm bbk TB
mBH long tubes x pipe no secondaries just mufflers
Ported heads
BIP box tune
BIP TCU
UPD 3k stall
Quaife diff
Clk wheels/ mt drag radials
Old May 10, 2015 | 10:03 AM
Hulk's Avatar
A Merc
Even with no injectors(although I think it was an over sight in him posting) he has meth which would give him more fuel
Old May 10, 2015 | 10:15 AM
  #32
sircl55amg's Avatar
2006 cls 55 amg
yeah it help afr and cooling a bit
Old May 10, 2015 | 11:29 AM
  #33
lm7's Avatar
lm7
2003 E55
The injectors were an oversight I do have the 550s and agree mph still low hard to tell what it is still pulls a bit of timing in 3rd gear so obviously that's contributing but I think I'm fighting some false knock. On the positive side my new weld/Hoosier setup is consistent on the 60s now 1.6 with esp off. In dyno more though still can't hook up best was a 1.8...
Old May 10, 2015 | 11:52 AM
  #34
Hulk's Avatar
A Merc
I knew u omitted the 550s
What are are 1/8 times?
Old May 10, 2015 | 11:58 AM
  #35
lm7's Avatar
lm7
2003 E55
7.3 @ 95mph
Old May 10, 2015 | 12:06 PM
  #36
Hulk's Avatar
A Merc
There's the problem, it's your 1/8. Your 60' at 1.60 is great so means something is happening down the 1/8
Old May 10, 2015 | 12:11 PM
  #37
lm7's Avatar
lm7
2003 E55
Could be the super lean 1st gear/ somewhat lean 2nd need a new tune.
Old May 10, 2015 | 03:58 PM
  #38
kustom2k1's Avatar
03SL55
"Trunk tank/killer chiller/ meth comes in at 90 degree iat"
Have you tried not running the meth for a pass? Trunk tank and KC should be sufficient.
Can you log data on your pass? I bet your IATs are a bit high. Maybe air in the line is keeping your combo from cooling efficiently.
Old May 10, 2015 | 05:47 PM
  #39
lm7's Avatar
lm7
2003 E55
I log every pass. Iats peak at Between 110-115
Old May 11, 2015 | 05:19 PM
  #40
Hammer Down's Avatar
2015 E63S, 2018 E63S
7.3 @ 95mph
As a reference use my 1/8 numbers 7.0@101.9 to gauge where you should be with your mods.
