Needswings or FTP intake?
I just got my 82mm TB and getting the snout bored, im going for a full intake at this point plus they come with a Y-Pipe. Any experiences on either? The FTP Y-Pipe is more of a (Y) while the Needwings is more of a (T) I noticed. Any feedback would really help. TIA
What's the price on both? Remember a member has already proved that the stock Airbox works very well just in case you wanted to spend the $$ elsewhere
S or SL intake tube on drivers side, stock boxes, 80mm Y, removed filters.
Whats stock boxes and whats 80mm Y and removed filters meaning NO AIR FILTERS at all and stock air filter boxes?
Little bit of everything actually, drag race here and there but mainly roll races and enjoying the power, im not building a drag queen but I do plan on buying a set of 16" CLK wheels w/ Hoosiers so I can take it to the strip. I already ordered 52lb injectors. After the TB, im pretty much done with it. I was possibly thinking looped fuel rails and eventually getting quiafe LSD. With my current mods though plus getting the the 82mm TB, do I really need the looped fuel rail or are the bigger injectors fine? BTW, with my current setup and on a tire, what should I realistically see 1/4 wise?
A ton of factors fo into achieving a good 1/4 et. If you can get it to stick, pull a 1.65 -60' and your ecu doesn't pull timing you could see a very good time.
Looped rail.....some say that you don't need it. I have it so its up to you but injectors yes will need to upgrade those.
Yes he removed the air filters at the track. Make sure that you buy a passenger side intake tube and install it on the driver's side.
I got my 82mm y-pipe from TTM. A good time would be low 11's or high 10's if the stars align. If your cooling is not in order your iat's could rise so high so fast that the ecu pulls timing to protect the engine. Have you split the cooling and have a separate cooling resevoir?
Do some reading on this forums before you order from FTP. Numerous people have been dissatisfied with their service.
Bruce @ TTM isn't exactly stellar to work with either
https://mbworld.org/forums/w211-amg/...ror-story.html
99 ford lightning
to me its crazy to go to the trouble of making 800 dollar intakes and trying to sell them however perhaps just like years ago for the lightnings and cobra jlp made ram air kits that made little to no difference on the dyno yet picked up a few mile per hour and knocked off a couple tenths at the track. so if anyone did a before and after with ftp or needwings at the track chime in.
