how to remove e55 timing case?
Old Apr 30, 2015 | 07:08 AM
e500slr's Avatar
2011 E63, 2013 CLS63
How do I remove the timing case on an E55 engine?
I don't mean timing chain by the way, I'm talking about the timing case that sits on the front and has all the pulleys on it and also hosts the timing chain.
I've already taken off the heads. Do I need to remove the oil pan to remove the timing case?
Old Apr 30, 2015 | 09:30 AM
Elhonaz's Avatar
W211 E55 2003
Yes lower oil pan needs to come off, there are couple bolts there that go through the upper oilpan to timing cover
Old Apr 30, 2015 | 09:47 AM
e500slr's Avatar
Dammit!! Gonna need an engine crane and an engine stand. Even with the heads off the engine is so damn heavy. I was surprised at how heavy the heads are, I'd say both heads are 130 lbs.
Old Apr 30, 2015 | 05:36 PM
Elhonaz's Avatar
W211 E55 2003
Sure! Makes life easier
Old Apr 30, 2015 | 11:41 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
www.alldatadiy.com
Old May 1, 2015 | 06:54 PM
e500slr's Avatar
Originally Posted by rockthemullet
I know but I'm cheap and don't wanna pay for a subscription I actually have the WIS/ASRA but it's not working for some reason. I'm trying to mend it right now but the database says it's empty when I clearly updated it.
Old May 2, 2015 | 10:20 AM
It's $27.....
Old Sep 25, 2018 | 04:36 PM
E55AMGFanatic's Avatar
2006 E55 AMG
I've been reading this thread, I know its old, but I'm needing a little bit of advice with a 2006 E55 Timing Cover. I'm in the process of replacing it, I'm seeing a little bit of conflicting info on the timing cover. I got the subscription at ALLDATADIY, and I've been going through it. There isn't any mention that the heads need to be removed when replacing the timing cover. Is that a requirement? The reason I'm asking is that because in one of the posts above it says that he'd already removed the heads and I've also seen a e55 engine rebuild (M113k) that the timing cover was put on first then the heads. Is that correct? I really would not want to screw around with the heads if at all possible. But I noticed sealant went in the area between the cover and the heads, not too sure how to do that if the heads are on. Any advice would be much appreciated!!
Old Sep 25, 2018 | 04:43 PM
new55's Avatar
04 55
Heads can stay on
Old Sep 25, 2018 | 04:44 PM
Either the heads have to be removed or both oil pans. The timing cover is sandwiched between the two.
Old Sep 25, 2018 | 10:40 PM
Tavs's Avatar
2004 e55
In my experience, if you are going to pull the timing cover, pull the engine and flip it over. Gives you a chance to reseal both pans and the rear main plate / seal. You will not have to replace head gaskets unless you bigger them up. I have done a many of front cover r&r and left the heads on. (272, 273 engines but same idea)
If you are planning on new head gaskets that is a different story. Also note that replacing chain rails may require the heads to be removed depending on what one.
My opinion, pulling oil pans and front covers in the car is wack. Raising the engine or lowering the sub frame sucks. You will get a sore neck from staring up if you have a lift and destroy your garage floor if you don't.
Old May 27, 2025 | 01:13 AM
Royalwaffles's Avatar
W203 C280 Luxury, W211 E55 AMG
Would it even be possible to get the lower pan out of the way enough to access those bolts holding in the timing cover from below within the upper oil pan without ripping the engine out of the car?
Old May 27, 2025 | 07:21 AM
cdk4219's Avatar
95 SL600
Probably not, simply because the pan is sealed with RTV, and it needs to be cleaned and resealed, there’s not enough room IMO
Old May 27, 2025 | 11:30 AM
Oh boy, I'm in over my head here... Got a link to a subform for.... lifting the engine out with a crane?
Old May 27, 2025 | 04:57 PM
SICAMG's Avatar
2005 e55 AMG
The engine is so easy to remove that you are better off pulling it and make life easy for your self.
