ECU Tune Pinging
Recently I fitted my E55 with a Eurocharged TCU Tune which has been great
Today I flashed a Eurocharged ECU tune on
Now upon boosting through 2nd gear I thought I heard it pinging just before it was shifting into gear, almost like a mild spray paint can"s" x10 rattling before gear shift @6700rpm (or what ever the tuned TCU shifts at)
* I am logging on every drive and I am going to be taking it to a dyno for a power/health run in a few weeks
My question is, since the ECU "learns" does it still need to learn/settle after a re-flash, I would have driven about 10kms tops and got the car up to operating temp before hitting the motorway and booting it
If it does then fine, it should adapt to the fuel I am using etc (98 Ron)
Otherwise I need to start logging and send these to Jeremy to fine tune
I just need to know to drive it out OR map/log and get it fine tuned by sending the logs back to Jerry
MODS: (pretty much stock) - Heat Exchanger/ 010 Pump, TCU Tune, Hurricane Scoops, SL55 Intake, Belt Wrap Kit, 1 step colder plugs
Thanks everyone
Looking through the data logs nothing looks out of place at the speed it would have occured, I'll go back through them again
I may need to do one more blast to make sure I just didn't go over some loose stones at that point that may have flicked up
It was the only time I took it all the way to the 3rd gear change, all the other times were close but I throttled off a couple of 100 rpm earlier and heard nothing
Im going to go back through my logs and check everything again, I may also rip my fuel pump cover off to check its condition as well
I did ask Jerry for "max power" so maybe it is a little too aggressive top end
Mine is also in NZ and I have the eurocharged tune and tcu.
Mine was specifically setup to be safe for 95 octane by the previous owner and thats what I usually put in it. Every 5 fills or so it might get some 98. Never had any problems with this car due to the tune.
IMO you likely have other problems unless eurocharged has somehow put the wrong program in it. But you say you wanted the max power tune.... yeah that could be an issue due to the ron/mon fuel differences between here and America but Jerry and Co should know all about that, end of the day though its still a remote tune. Id get a tune thats safe for 95 then run 98 like you obviously are and it shouldnt be an issue.
Also note there is a shed load of heat shielding around the exhaust areas (footwell area) on this car maybe with the extra rpm you are making something resonate??
You have star so you should be able to log what cylinder is pinging hardest? Did you have the windows down or something?? I cant hear jack from this engine with all the sound deadening going on. When I pulled the drip cover out of the hood and could hear the supercharger like crazy loud yeah I could understand you maybe hearing some ping but for the ping to be this apparent id be surprised if you havent already cracked a ringland.
Checking first thing this morning I have found the bearing on the SMALL drive belt idler to the lower right of the supercharger pulley is on its way out
There were no issues recorded in Star so my guess is it was bearing noise at high rpm and even a possibility of a ball bearing coming out of it and bouncing under the floor pan
