Losing To Cars That I shouldn't be???
No tune yet, although I will be modding soon. Of course, after I get everything checked and fixed.
To be honest, I'm not a big fan of the track. I'm more of a taking off on a red light or punching it on the freeway, but point taken.
FWIW, I know this is a total noob move but I took a stopwatch and did three 0-60 runs. I got 5.1, 5.1, 5.2... From what I've read we're supposed to be 4.3 stock.
Odds are, like mentioned above, the supercharger probably engaged in the beginning but would disengage shortly after. Only thing is I never once felt a loss of power. I would think if the supercharger went out I'd really feel it.
2005 E55 amg
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
You have a fuel smell.... so possible leaky fuel pump / tank / fuelling issues
You also state that have a possible vacuum leak that needs addressing
You have a Loss of power..... most likely IC Pump (IAT's can be viewed via Torque or another data logging set-up - they are not the same thing as your "engine" temp)
Yet you are out there trying to and continuing to race?![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
I would look into fixing these issues and get some logs before putting the foot down and before any detrimental damage is done
Good luck with it all
Good luck with it all![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
[QUOTE=Leempolo3;6450599]
QUOTE]
Theres gotta be something majorly wrong if you weren't able to run a 4.3 on your stopwatch, Im sure that's the most accurate method I hear NHRA is actually switching to stopwatches next year!
QUOTE]
#32
[QUOTE=nickgbmx;6452426][QUOTE=Leempolo3;6450599]
So even with me saying "FWIW" and acknowledging it was a noob move, you still decided to chime in with that comment huh? Hope you feel better about yourself now
#33
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#35
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
What happens is, as the IAT goes up the ECU pulls timing = power loss.
Now when the IAT gets too hot (heat soaked) then the SC comes off line and your E55 turns in to a 4 cylinder Camry, and you know it with out a doubt.
#36
2004 E55 AMG, 2005 E55 AMG (Sold)
what tires do you have on & how much meat is on them? i used to spin through all 3 first gears until i switched to brand new PSS and even still will spin off the line a bit even on a good launch.
these newer AWD cars that you are racing will jump on you off the line, that is not a surprise to me, but once you hook up you should see them quickly fading away in your rear view. it really shouldn't be more than a second or so of joy for them before you are gone. 0-60 of 5.1 is horrible and definitely not right ..
its really easy to know if its your IC pump. when you first take out your car, no prior pulls or hard driving, put it in 3rd and do a pull from 40, even with a failing IC pump, that first pull should still feel pretty much like full power. its the subsequent pulls after that initial one that you will start to feel like you are in a C300 and not an e55.
like others mentioned, get a bluetooth OBDII & use with torque app to watch IATs ...its helpful, especially now that its starting to get warm out
out of curiosity, do you know the setup of the 435 you raced? with the new cars it makes a big difference- a stock rwd 6 spd manual 435i will be a full .5 seconds slower off the line then a stock awd auto 435i
i walked a new m3 coupe the other day, i had 4 people in my car vs. just the driver in the m3 and HE was the one who wanted to race. we pulled from 20 to 80, afterwards he pulls up and asks WTH mods i have in my car, i said of course i'm stock
..poor guy must've had some buyers remorse when he got home
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
#37
..poor guy must've had some buyers remorse when he got home ![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Agreed. I have a bluetooth OBDII on its way from amazon.
The 435 was stock auto... If I'm not mistaken, I think the Infiniti was AWD and the 435 is a RWD. Either way, it shouldn't have even been close. I can't wait to get it all fixed and rape my buddies 435
![action](https://mbworld.org/forums/images/smilies/action1.gif)
#38
#40
I have some ****ty falken's on them. I'd say 60-70% tread left so somewhat newer. I'll definitely be looking to get some PSS on them soon.
The 435 was stock auto... If I'm not mistaken, I think the Infiniti was AWD and the 435 is a RWD. Either way, it shouldn't have even been close. I can't wait to get it all fixed and rape my buddies 435![action](https://mbworld.org/forums/images/smilies/action1.gif)
That could be a lot of your issue to is wheel spin. I just put on a brand new set of Pilot Super Sports and man what a difference it made from the 60 percent Hankook Ventus V12 I had, it feels like a whole new car. As everyone else stated monitor your IAT closely and try and feather the throttle out of the hole, it may seem like its slower but I assure you a partial throttle launch with traction will net you much better results than a full throttle launch and spinning through the first two gears
#41
1999 MB C43 2004 E55 AMG, 2004 Suzuki GSXR, gl63
Just replaced my intercooler pump yesterday, and I'm very pleased, car still felt relatively fast, but felt sluggish at high speed. What I mean by that is that it felt like it was surging in 4th and 5th. It felt like the power wasn't smoothed, I figure it was pulling timing. After the replacement it feels like it has all the low end torque back where it should be. Even more please with the fact my mechanic only charged me 50$ to change it out!
#42
And I just confirmed what everyone was suspecting. After plugging in my OBDII bluetooth that I received in the mail yesterday, my cruising IAT temp was 145-150f! The weather outside was 65. After I gave it some throttle, it went up to 206!
The temp took forever to come back down as well. I'll be installing the new Bosch pump this week.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#43
https://mbworld.org/forums/w211-amg/...necessary.html
#44
05 E55, 07 ML500
When you do the install, you may want to split the system as long as you have it open, only requires some hose and small tank.
#45
#46
#47
![Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive](https://mbworld.org/forums/images/misc/amazon_icon.gif)
Can anyone help with my previous post? Last thing I want to do is find myself in the same situation with those mods and cooling.
#48
I'm of the opinion that the split cooling without adding a large tank will have very minimal effects on IATs. If you go that route, at least run straight water (with corrosion inhibitors) for your use, I think it is actually a waste of time and money. (I do have a BMW reservoir if you're interested though)
#49
