Losing To Cars That I shouldn't be???
Old Jun 8, 2015 | 01:46 PM
  #51
Leempolo3's Avatar
2006 E55
Originally Posted by uraberg
I'm of the opinion that the split cooling without adding a large tank will have very minimal effects on IATs. If you go that route, at least run straight water (with corrosion inhibitors) for your use, I think it is actually a waste of time and money. (I do have a BMW reservoir if you're interested though)
I was planning on using mostly distilled water and water wetter with a very small amount of antifreeze. I was hoping to be able to get one good run without pulling timing or the S/C shutting off with this setup.
Old Jun 8, 2015 | 02:02 PM
  #52
uraberg's Avatar
2006 E55 AMG
You and I both have the same sort of needs.
from what I gather, in order not to pull timing on top of a long pull, you either need to start at very low temperatures (Ice in a tank, or killer chiller), or have a more efficient way of cooling the charge. (methanol/water injection).
I'm very much leaning towards methanol injection at this point. I plan on spraying wiper fluid right into the supercharger.
Old Jun 8, 2015 | 02:35 PM
  #53
kponti's Avatar
E63
Originally Posted by HeissRod
With the larger HE?
Yes with the FTP HE. Mind you ambient was around 90 to 95. With split I will be 100-110 degrees within 90seconds or less IAT where without split I will hover around 115-120 for a few minutes. This was in stop and go, on the freeway, its faster recovery for both
Old Jun 8, 2015 | 04:39 PM
  #54
Leempolo3's Avatar
2006 E55
Wow really? All I want to do is take off on someone here and there, nothing crazy. One of the reasons why I decided not to go with a smaller S/C pulley or TB was to not go crazy on the cooling. This is pretty frustrating...
Old Jun 8, 2015 | 04:45 PM
  #55
uraberg's Avatar
2006 E55 AMG
You don't have to mod anything. Even stock, it's a pretty good car. You'll probably never realize when you get in the first stages of the computer pulling a little timing, because you're well in the triple digits by then. (depends on ambient of course)
Old Jun 8, 2015 | 05:07 PM
  #56
Leempolo3's Avatar
2006 E55
Ya they are, but a little more power never hurts
Old Jun 8, 2015 | 10:08 PM
  #57
Leempolo3's Avatar
2006 E55
Also, about distilled water and water wetter... I live in Socal and the temps never go below 40 in the winter. Do I really need to add any antifreeze? Can't I just run just distilled water and WW year round?
Old Jun 8, 2015 | 10:18 PM
  #58
uraberg's Avatar
2006 E55 AMG
Yes you can. In the whole system, if you're comfortable.
Old Jun 8, 2015 | 11:03 PM
  #59
Leempolo3's Avatar
2006 E55
Thanks bud. Do you know when it be appropriate to change/flush with that setup? Is it once a year?
Old Jun 9, 2015 | 07:00 AM
  #60
uraberg's Avatar
2006 E55 AMG
I should probably throttle back a little, and say that:
From a fear of freezing standpoint, you're OK with H2O and WW.
From a fear of boiling standpoint, you're possibly OK as well. (although the SC generates a lot of extra heat, the increased heat capacity of H2O vs 50:50 will probably compensate.)
Now for corrosion resistance and lubrication, you will have to do research before you commit to throwing your coolant out.
And I would flush often if you're going this route. at least twice a year.
Old Jun 9, 2015 | 03:20 PM
  #61
Leempolo3's Avatar
2006 E55
In that case I'll keep a small amount of antifreeze in there lol. Thanks for all your help!!!
