plugs wires and valve cover (passenger side) done! with some pics and my experiences.
Old Jun 17, 2015 | 01:14 AM
gjunon's Avatar
04 E55 AMG
Spent around 5 hours doing it right. I was not happy with the rear drivers side spark plugs... PITA to remove them. The spark plugs had 109k miles on them. A few of them look a little fouled.
Car is much more responsive now. I also noticed a great improvement with engine idle.
The air boxes do not need to be completely taken off as you can rest them on top of the supercharger making the job a bit easier. I also broke 4 of the brittle tabs holding the coil pack wires to the packs. you can set the whole string of coil packs on top of the supercharger as well. I took them off one at a time as to not get them mixed up when I put the new plug wires in. you won't need zip ties as there is very little play in the wires anyway.
putting the boots on was a pain. I used the spark plug removal tool to press them on till they clicked (it takes a lot of pressure.) I also noted that is was very easy to bend the internal part of the new wire that connects with the coil pack. Be careful to have a strait shot when applying force to the coil pack with the wire or you may bend it.
Q tips will not fit very well into the gasket grove to clean them. I used paper towels to get into the grove to clean it out.
I think my gasket was actually fine about 4 of the bolts holding the valve cover on were pretty loose I could have probably broke them loose with my hand.
Passengers side
passengers side was seeping oil pretty bad.
passengers side
Another angle of the passengers side
Another angle of the passengers side.
Passengers side
The clio and grounding wire you need to remove on the passengers side.
Looking great after 109k miles!
Very clean.
Had some darker oil spots on the inside of the valve cover.
Darker spots were mostly on the side walls of the cover.
Another angle with the cover off.
Starting to put the new plug wires back on the drivers side
Another angle of the drivers side.
Drivers side
Finally all back together! Also the little clips were extremely brittle broke 4 of them.
driver side on the bottom passengers side on top.
Old Jun 17, 2015 | 06:10 AM
Hotsauce55's Avatar
2005 E55
Nice writeup. I will be tackling some underhood maintenance in the next few weeks as well.
Old Jun 17, 2015 | 07:38 AM
J J's Avatar
J J
What kind of plugs did you use?
Probably need to do this too and wondering what brand and if I should use colder plugs.
Old Jun 17, 2015 | 08:30 AM
novae500's Avatar
W211
nice write up and pics
Old Jun 17, 2015 | 10:39 AM
gjunon's Avatar
04 E55 AMG
JJ I used one step colder plugs LFR7AIX from NGK as I am planning on adding a SC pulley eventually. I bought them for 100$ from the site below.
http://www.ecrater.com/p/14263473/16...id=81021614899
Old Jun 17, 2015 | 10:45 AM
gjunon's Avatar
04 E55 AMG
I recommend you get plenty of different length extensions as there isn't a whole lot of room to work with, and you'll find your ratchet getting stuck against the firewall.
Old Jun 17, 2015 | 10:47 AM
Hotsauce55's Avatar
2005 E55
Thanks for heads up - arguably I have too many tools, so I hope to be ok.
Old Jun 17, 2015 | 05:28 PM
2000UZJ's Avatar
E55
How does it run with the colder plugs? I need to do plugs very soon as well as VCG
Old Jun 17, 2015 | 08:50 PM
gjunon's Avatar
04 E55 AMG
Runs great. I have no problems so far. Idle is much smoother, and no problems with acceleration.
Old Jun 17, 2015 | 09:10 PM
cm60k's Avatar
Great Write-up MaaaaaaaaaaaaaaN..
ZAYED,,
Old Jun 18, 2015 | 01:50 PM
gts007's Avatar
06 E55 AMG, 86 Corolla,87 E30,02 LSB M3
nice. i did mines was crazy to clean off all the build up.
Old Aug 30, 2018 | 08:51 AM
MACEDON's Avatar
05 E55, 98 CLK320
sub
Old Aug 30, 2018 | 09:04 AM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
How much sealant did you use for the new gasket and where did you apply it to?
Old Aug 30, 2018 | 09:43 PM
gjunon's Avatar
04 E55 AMG
a very thin bead will work well applied to the groove of the valve cover.
