Transmission slipping HELP
I need your help with figuring out what's going on with my transmission. I was driving to work one morning and reached the first intersection near my neighborhood. My car was in drive. The light turns green and I start to accelerate. I got up to 15mph when all of a sudden the transmission totally slips in drive, manual mode or reverse. There was also a weird winding noise every time I gave the throttle some gas. I ended up towing the car home. The next day I started the car and everything was back to normal. I drove the car up my street and back with no problem. Today I drove it a little further and it totally slips again(Nothing in drive, reverse, manual mode plus the weird winding noise). I turned the car off for 5mins and back to normal, so I drove the car back home with no problems. There are no signs of trans fluid leaking. I can't even check the trans fluid level(Don't have the special tool). Is there a chance that my transmission needs to be replaced. Has this happen to anyone else? I haven't towed it to Mercedes yet because the only dealership we have is very far from where I live. Any help is greatly appreciated!
This is an all stock 2003 E55 with 50k miles
Good Luck
Good Luck
straighten out a coat hanger and put it in the trans dip stick hole. if the fluid level is less than an inch you are low on fluid
