CEL after header install *help*
Old Jul 9, 2015 | 09:37 PM
E55AMGGG04's Avatar
04 w211 E55
I just had EC mid length headers installed and even after the flash I am still throwing a CEL. P0141/P0161 are the codes. I noticed when I popped open the hood that the O2 sensor on the header is in. The second O2 sensor is not in there. They are in the box with the stock headers.
Should those second O2 seniors be in there also or is normal to not put them back in? Any information is appreciated.
Old Jul 9, 2015 | 10:40 PM
sircl55amg's Avatar
2006 cls 55 amg
the o2 sensor must be install normaly.... or the tune is problematic
Old Jul 9, 2015 | 10:45 PM
Hulk's Avatar
A Merc
Tell your tuner to turn off the rear O2 sensors
Old Jul 9, 2015 | 11:05 PM
E55AMGGG04's Avatar
04 w211 E55
I'm going to have my installer put the rear back in. If I don't put them back in wouldn't it cause some type of damage to the engine?
Old Jul 9, 2015 | 11:41 PM
Rocman8's Avatar
E55
they will not cause damage to the engine but the ec tune needs them to be installed for the check engine light to stay off. or you can have the monitor disabled with a star. they are only used for emissions to monitor the efficiency of the primary cats.
Old Jul 10, 2015 | 12:40 AM
Hulk's Avatar
A Merc
^^^^, you can turn off the rears with star
Old Jul 10, 2015 | 08:27 AM
E55AMGGG04's Avatar
04 w211 E55
Thanks for the replies fellas.
Old Jul 10, 2015 | 08:33 AM
jmb614's Avatar
E55 AMG
Or you can get a set of 90 degree extenders from Bruce. Ever since I got those and had the wiring for the secondary O2's soldered in no secondary CEL's.
Old Jul 10, 2015 | 08:41 AM
Hulk's Avatar
A Merc
True J, I don't know if he still carries them though
Old Jul 10, 2015 | 08:51 AM
kompressede's Avatar
Sold - 05' E55
Agreed, go with the 90 degree extenders.
Keep in mind, you'll have to take care of the readiness prior to an inspection. This can be done through das.
Old Jul 10, 2015 | 10:24 AM
LNDMISSL's Avatar
E55 W211, G55 W463, 2010 GT500, 2008 S4 Cab (Wife), LR4
OP, how do you like your new headers?
Both upstream & downstream o2's are still installed on my car. I went to Eurocharged Toronto and got my car dyno'd. During that time, they turned mine off. I havent had any issues since.
I'm just curious what I need to do when inspection is due.
Old Jul 10, 2015 | 10:35 AM
Hulk's Avatar
A Merc
The sec O2 can be turned off via star or tuning, when inspected they will see they are not working
Old Jul 10, 2015 | 11:00 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
We use these for cars without catalytic conveters
http://bigdaddiesgarage.com/mini-cat-cel-fix.html
Old Jul 10, 2015 | 12:14 PM
novae500's Avatar
W211
or use 42dd o2 extenders. VW guys use them as well.
Old Jul 10, 2015 | 12:39 PM
E55AMGGG04's Avatar
04 w211 E55
I went from tune/pulley dyno tune which ran very strong to the box header tune. I feel the top end power more than anything else. I still need to give it time to adapt.
Old Jul 10, 2015 | 08:17 PM
E55AMGGG04's Avatar
04 w211 E55
Put the rest sensors back in and CEL is gone ��
Old Aug 6, 2015 | 11:50 AM
LNDMISSL's Avatar
Are your o2's turned off?
Old Jan 9, 2018 | 05:07 PM
blackbenzz's Avatar
haters crazy
Oops
Old Jan 10, 2018 | 01:43 PM
MACEDON's Avatar
05 E55, 98 CLK320
All 4 sensors should be in place, then reset your ECU to reset fuel trims, and then install a tune to get the most out of them.
No need to code out the rears, only if you remove cats/
Old Jan 10, 2018 | 09:01 PM
ranger101's Avatar
E55 AMG
2 and 1/2 years too late haha
Old Jan 11, 2018 | 08:16 AM
MACEDON's Avatar
05 E55, 98 CLK320
lololol
Old Jan 11, 2018 | 09:59 AM
builtbyfood's Avatar
2004 E55
If the tuner turns off via his tune, you will fail emissions and it will show not ready. It is best to disable via star in the ECU. This method will allow the rear 02's to be "ready" and will show that during emissions and not raise any flags.
Old Jan 11, 2018 | 07:50 PM
tw2's Avatar
tw2
Thanks for the old thread bump. I never knew about this product. Looks like a great solution when STAR is unavailable.
