Battery Protection w/ aftermarket sound system
Old Jul 27, 2015 | 09:02 PM
GordonTse's Avatar
03 E55
hi all, i dont post on here much but having an issue with my '03 e55. have an aftermarket sound system put in. if the subs hit a bit hard the vehicle goes into Battery Protection mode and shuts off convenience functions. radio, cig lighters, etc.
system consists of 2 x 12" Focal subs. Audison AV5.1K Amp. Focal components in the front and Focal coaxials in the rear. Just had brand new Odyssey battery put in by the same shop that installed the system. Alternator is brand new.
Shop is very reputable and works on all high end vehicles. They have never seen this on any Mercedes they've worked on. They ran tests to the best of their capability and couldn't figure why its happening. Just curious if any members on here has had problems with aftermarket stereos.
thank you
Old Jul 27, 2015 | 09:37 PM
vietjdmboi's Avatar
'04 E55 AMG
might want to post on diyma.com to see what they think. not sure what the sub ratings are but could be too much?
Old Jul 28, 2015 | 01:56 PM
JoeNobody's Avatar
Mercedes
Sounds like the sub amps are drawing enough juice to momentarily drop the voltage and trigger low battery. Hook up a multimeter to the battery while engine is running and music is playing, and see what the voltage drops to. If it is dropping, then try installing a large farad capacitor as that should help with the big current peaks.
Old Jul 28, 2015 | 02:15 PM
Denroll's Avatar
'06 E55
How about a beefed up alternator from Ohio Generator?
http://www.ohiogen.com/html/catalog.html
Old Jul 28, 2015 | 03:29 PM
JoeNobody's Avatar
Mercedes
Stock alternator is 100amps, and should be plenty for all but the most extreme systems
Old Jul 28, 2015 | 03:36 PM
Funk Season's Avatar
06 Mercedes-Benz CLS55 AMG
this is exactly it! i go through the same issue occasionally with my jl 1000/1
Old Jul 28, 2015 | 07:27 PM
Luxury4play's Avatar
E55
Amps are drawing enough power for the car to think the charging system is failing. Best advice i can give is may put a large capacitor between your battery and amp (it will be the buffer between deep bass notes, amps will suck up the capacitor charge instead of your battery).
Old Jul 28, 2015 | 08:36 PM
Dat Boy I's Avatar
06 e55
Seen this plenty of times on mercedes veichles car is just seen a over load in current draw. A second gell cell battery and pac 200 isolator will do wonders. Take care.
Old Jul 28, 2015 | 10:51 PM
GordonTse's Avatar
03 E55
The audio shop checked voltage drops and all that with multimeter. they said even with big hits of bass, voltage only dropped down to 13.8V. Sad because system is tuned down at the amp and still has so much more potential.
Old Jul 29, 2015 | 01:06 AM
JoeNobody's Avatar
Mercedes
Cheap multimeters don't show smaller spikes that are probably upsetting a Mercedes sensor. Install a farad cap, and see if it fixes it. Can also check voltage at the amp itself when the cutoff occurs. A second battery and an isolator would also probably fix it, but try a farad and be done with it.
