2005 e55 amg, 2005 audi s4, 2000 audi a4 1.8T (big turbo)
Originally Posted by Rocman8
are you in the USA? thats covered under a 15 year warranty extension and you would get a complete tank with all new parts.
Yea im in the usa is that something u just go to the dealer ? , and that was the entire problem of the stalling, roaming idle,jerking ,fuel smell etc, the car runs like a champ now, still smells like gas tho.
Fuel pump recall fix.
Well i asked they said they not doing them anymore, then they said they would charge me 150 to check it if it qualify they would fixbut i would pay some of it bla bla so i said fk it and ill fix it my self 😃
Your dealer "is not doing the fuel system warranty repairs anymore"???
You need to call another dealer. Or if you have to use that scam dealer, instruct them to do the repairs and you pay for them out of pocket. Then mail the bill to MBUSA for reimbursement.
Yea thats what they said , plus i dont have an oem pump looks like an aftermarket its an airtex e8572m or is that oem?
Do not spend any of your time or money fixing this. Have Mercedes dealer replace entire tank, along with fuel sender and pump.
Call your dealer back up and tell them you want brand new tank and new sender and new pump. If they refuse, then send a letter to NHTSA explaining that Mercrdes is refusing to honor its settlement. Hell I'll even write the letter for you. Just get audio/video or an email showing the dealer refusing to fix your car, and I'll write up the rest. The BS that Mercedes is doing about these fuel issues is absurd.
Well i called the benz of valencia here in California maybe i can try another one
That's like $900 worth of parts for just the fuel pump assembly and fuel sender, and that's if you order from an online company. I don't even know what a new tank costs.
Well i fix it as mention before on this post was not much to it the top hat of the fuel pump assembly seem to be the issue along with the inner fuel pump harness that was it just thought i called and see if they could replace it all without much hassle =(.
Well found my fuel smell , plug melted and made a hole on the housing small little hole patch it problem solved, fixed the barbecue plug as well it should run better now.
Melted housing from plug.
I patched the little hole now i blow on the plug housing and no more air escapes or vapors.
so ATK , what did you end up doing? I have the same identical problem as you do, damn it sux , i REALLY DID get beat by a civic yesterday with the car stalling at 4300rpm !! driving me nuts!! MBZ stealer told me same thing ... pay them $200 to diagnose it and MAYBE they will do the work for free. They also admited that they changed my gas tank and pump in 2016 right before i bought the car... i'm on the fence on what to do... pay them the $200 to diagnose it and hope i don't loose out , buy another one myself for $500 and do the work or upgrade it to a high performance pump ( if they make one for this car)....
Did you figure out why this happened in the 1st place? with me i'm pretty sure when I got it tuned they f**ked up on the fuel because my pressure is 9psi and i think that's why my plug melted since it's sending too much current to the pump and I only have the stock injectors.. bit not 💯 % sure so just curious if you also have the stock injectors or not or did it happen after you got the car tuned???...I just really want to avoid this from ever happen again if possible...
ANY INPUT FROM ANYONE IS MUCH APPRECIATED!!!!
