One of a million wheel/tire fitment questions
Hello all,
I plan to purchase some enkei rs05rr for my 05 w211, but it's hard for me to find answers to my questions. Being as most people go to 19s or 20s.
So here we go...
I plan to run:
18x9.5 et35 fronts with 265/35/18 Michelin pss
18x10.5 et35 rears with 295/35/18
Lowered about an inch below sport2 with links.
I want to keep negative camber to a minimum, as this is mainly for more traction/less weight over the stock wheels.
I will also be running wobble bolts and hubcentric rings so that I can run the 5x114 and have wheels that are easier to sell down the road.
How are we looking with these measurements?
I don't want to run spacers, or roll the fenders.
Thanks in advance!
- travis
So here we go...
I plan to run:
Thanks in advance!
- travis
I think the offset is too high in the front. I tried a 9.5 et 35 in front and the barrell rubbed the calipers. There is a member running 9.5 up front with et28 I believe. It has good clearance and sit pretty flush.
The rears? I got nothing. Sorry
I'm wondering if it was because of the barrel inner bore itself, most enkei wheels are made to accept bigger brakes.
I don't want to, nor can I run spacers with wobble bolts...
Not sure what size they may have with a better et and "mid concave" face
What about 285? I just put on a 77mm fsp and belt wrap kit. As well as the plm heat exchanger and 010 pump. The car eats the 265s like nothing
I need something that can handle it better, and fit
I've read that people have ran 18x10.5 I'm 19s and 20s. Et35.
I've also heard that any higher than 35, and the tires may hit the inside of the well on the back side of the wheel, causing the "fishtail" people talk about...
Received 1,488 Likes
This place is a joke.
I'm running widened 18x10's on the rear, originally 18x9 with ET 35, if you want to do the math, I added 1" to the inside of the wheel. Running 285/35/18.
https://mbworld.org/forums/w211-amg/...weldcraft.html
The way to fit aftermarket wheel/tire combos is to pick the tire size that you want, or that fits, then choose the wheel width and offset, if that makes sense. In theory you would test fit a tire by itself where you want it to go, without a wheel, with the car on jack stands, then figure out what wheel you need.
The 295/35 you want is a bit tall for my liking on the rear. Not many tire choices in 18's for our cars unfortunately. Something like a 305/30 in back might work, if anyone made one, or a theoretical size (height) between the 285/35 and 295/30...the 285 is a bit tall and the 295 is a bit short.
This is the first time I have heard this. The "fishtail" or wagging back and forth under acceleration is caused by bad rear alignments values.
Well, I'm hoping these wheels work. Because I have already ordered the rears. And being as the michelin pss are on national back order (what my tire guy told me) I'm gonna probably have to get some 285/35/18s that I've found slightly used on craigslist. The 265s that are on now, just can't even come close to handling the power, and the tune isn't even done yet...
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
You should really consider installing rear toe links such as those offered by Shardul. This will provide greatly improved stability under hard acceleration and will take the associated stress off the rear sub-frame, thereby eliminating the chance of shearing the sub-frame bolts.
