Heeeellllllp abs esp defective!
W211 E55 AMG
Ok so just replaced my front wheel bearings, started the car to drive and I get abs and esp defective, first off the car wouldnt accelerate unless I turned off the esp, then it drove fine, had the alignment done and warnings are still there but don't have to turn off esp to get it to drive
Tried turning the wheel side to side made no difference, when I first start the car the steering is mega light, also the speedo doesn't work then all of a sudden the the speedo works and the steering gets heavy.....
The bearings I used were a kit and I am worried that the seal doesn't have the magnets in after doing a bit of research, do I just bite the bullet and buy 2 new hubs from Mercedes to save myself any hassle or have I just done something wrong?
W211 E55 AMG
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Yes, the tone ring is in the inner seal. If the spacing between the sensor and tone ring are incorrect then you will have this fault occurrence.
