question about split cooling modification
Old Oct 26, 2015 | 05:14 PM
FLE55AMG's Avatar
2006 AMG E55
I have been reading conflicting information here. I'm upgrading my cooling system in preparation for boost modifications. I have already installed the 010 Bosch pump and have the PLM HE ready to go in. I found fabtech makes a kit with a BMW power steering reservoir. I have been seeing people say it's not needed because the T fitting does not allow the engine coolant to mix with Supercharger cooling. What is the final verdict? Do I need to split cooling or don't bother.
Thank you in advance.
Old Oct 26, 2015 | 05:41 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
You only need to split the cooling loops if you plan on running a different fluid on the H/X side, or if you plan on using a tank to store cold water. Otherwise the H/X and engine radiator do share fluid, but there is minimal-to-no heat transfer between the two since the reservoir is the only common part of the two loops.
Old Oct 26, 2015 | 05:43 PM
FLE55AMG's Avatar
2006 AMG E55
Thank you! great to know!
Old Oct 26, 2015 | 06:01 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Old Oct 27, 2015 | 03:44 AM
Max.H's Avatar
E55
Joe, could you clarify… What reservoir are you talking about? In stock form?
Old Oct 27, 2015 | 10:25 AM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
Good basic information that everyone here should know but surprisingly I don't believe is common knowledge in this forum. Cheers Joe.
Old Oct 27, 2015 | 10:38 AM
JoeJErnst's Avatar
It's the tank where you add engine coolant.
Old Oct 27, 2015 | 10:43 AM
FLE55AMG's Avatar
2006 AMG E55
We being one of the newest readers to the forums there is a lot of information to digest. Also, it's not always clear what the agreed upon answer is by the community without separating the topic and asking a pointed leading question to get an objective answer instead of subjective comment.
I have learned a lot already and am always looking to learn more.
Old Oct 27, 2015 | 11:53 AM
Maybe I didn't word that right. I was inferring that not just new members but a lot of long term members also were probably not aware of this (including me). We're all always learning...
Old Oct 27, 2015 | 02:28 PM
JoeNobody's Avatar
Mercedes
Splitting the cooling loop will yield better results. It's not dramatic, but it is there (and since it's cheap and simple to split the loop, why not).
It makes sense since, because even though the coolant in the intercooler does not directly mix with the engine coolant, it still flows past a T barb connected to engine coolant, so some heat transfer does occur.
Old Oct 27, 2015 | 02:34 PM
JoeNobody's Avatar
Mercedes
By the way, the BMW reservoir is vented to open air, it does not allow the coolant loop to pressurize, and coolant sprays out under heavy coolant flow. Previously I sealed my reservoir up and installed a grease pressure valve fitting, but that only last so long before the valve wears out.
I'm also about to install a much better solution that allows the loop to pressurize, won't spray coolant, and it should look factory'ish. I'll post photos when it's done.
Old Oct 27, 2015 | 02:37 PM
viper04's Avatar
I was wondering if anyone has ever data log to see what the difference in temp is. With and without split cooling. That I have not found i'm sure someone as.
Old Oct 27, 2015 | 03:48 PM
Max.H's Avatar
E55
Bingo
Old Oct 27, 2015 | 03:49 PM
FLE55AMG's Avatar
2006 AMG E55
I'm wondering myself? I just bought a data logging software/hardware to log my car stock VS after modifications.
Old Oct 27, 2015 | 08:32 PM
Max.H's Avatar
E55
Right now Im seeing 30 degrees above ambient in stop and go and about 20-25 degrees above ambient cruising 40-50mph. Not split just CM30 and cooling system bled.
Old May 6, 2026 | 09:36 AM
Apjcustoms's Avatar
98 SL500 sport
how did you go about sealing and pressuring the split tank setup ? I’m about to do mine and would like to do it correctly
Old May 6, 2026 | 11:39 AM
bobgodd's Avatar
2004 E55
It shouldn't be pressurized, just find a way to vent air/bubbles at the highest point. Usually that would be your tank.
Old May 8, 2026 | 08:35 AM
Apjcustoms's Avatar
98 SL500 sport
ive done this mod on my sl55 but noticed even with a new pump minimal coolant circulation and now im bout to install on my s55 and aside from drilling and tapping a fitting to the highest spot on the bmw tank for the bled line was curious about pressurizing the system and what affects that would have on IATs . When I followed instructions last time it had me only using the center male port on the res and capping off the other and due to not wanting to stray to far from the instructions declined to connect that bleed line that goes back to the oem expansion tank to an additional fitting on the highest past of the tank which would then allow the units to self bleed . Unlike many others I keep the level at 1/2 way point and have yet to have any actual coolant leave the res
