drag tire test on street no limp mode.
Old Nov 20, 2015 | 03:56 PM
99lightning's Avatar
99 ford lightning
so recap for what ever reason 255 50 16 m/t drag radials caused my car to go into limp mode even had a 1 and 4th gear slip code. today I tried my hoosier 26x9x16 tires bolted them on swayed all over the place up the road no limp mode. I actually layed on the converter to 3000rpms never did that but then I rolled into tires spun obviously on the street but it was not like they boiled it actually shifted pretty good it didn't cut out. I think at the track I was not building it up enough and I was getting too much flash and then it would shocked the tires causing a bad tire spin and causing the 1-2 shift to be really lousy. I did try launching in manual and then pressed the button for sport mode right after and that seem to shift pretty good but you have to do it right away or it will hang up.
Old Nov 20, 2015 | 06:12 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Yours is an 06 right? They can be finicky when running a taller tire.
Old Nov 20, 2015 | 07:23 PM
99 ford lightning
Its a 05 checked it with star no codes after about 6 launches.
Old Nov 21, 2015 | 10:44 AM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
I make sure I found tires that were very close in height.
Old Nov 21, 2015 | 10:50 AM
99 ford lightning
test on the street first I wasted lots of money going the track race fuel etc only to have my car mess up and not shift right.
Old Nov 21, 2015 | 03:50 PM
tscales's Avatar
I just got the new tires on the wheels, but I'm not worried. For the E55, they're stock wheels with 275/35-18 instead of 265/25-18.
I've run them on my SL65, replacing 295/30-19. Same basic size in diameter. Runs great.
Old Nov 21, 2015 | 06:56 PM
Ruthle55's Avatar
e55 amg
What is the over-all diameter on your setup? Im 25" front, 26" rear, cars an 03. ET streets, 1.6-1.7 60fts, never had an issue.
Old Nov 22, 2015 | 05:15 AM
99 ford lightning
factory front tires qtp tires are 26.1 according to the specs same as mt 255 50 16 so who knows.
Old Nov 22, 2015 | 05:59 AM
RaceHorse's Avatar
CL65
I'm glad you resolved your issues somewhat by swapping the tires. I think matching stock height front (25.7") to stock height rear(25.3") is more important that both the same since from the factory the rears are slightly shorter. Weird thing is both drags you mentioned are both the same height of 26" on paper, yet one is a problem.. Have you put them next to each other with a straight edge across the top to see if there is any real difference? Maybe the slight difference is what is causing your problem since the car is expecting taller tires up front. Either way, get them hot, launch hard and hopefully they stick!!!! Good luck.
Old Nov 22, 2015 | 06:05 AM
99 ford lightning
race horse, when I had hooiser drag radials 255 60 16 they would fit in the spare tire area in trunk no problem and my qtp's drop right in the mickey was a tight fit so I thought hmm how tall are these. funny thing is the hoosier quick time pro will grow as you go down the track. but either way no limp mode. I think with good track prep I can get a good run now and yes I was not building the stall up enough causing too much flash blowing the tires off and making that 1-2 shift do something crazy. It spins on the street with drag tires but I can get through first gear and have the 2nd gear shift not do anything weird. It just sways like crazy but I guess its better then limp mode
Old Nov 22, 2015 | 10:49 AM
boostiality's Avatar
2004 E55
Just wanted to contribute, I have found that 17x8.5 clk55 rims work for both my cls55 and e55 utilizing 275/40/17 Nittos. No errors, cruise works, etc
