Rear main seal, what else?
My question is, is there anything else that should be done while that area is accessible when replacing the rear main seal? I'm already due for a transmission flush, filter, fluid change and plan on replacing the 13 pin connector too. What else should be done as preventative maintenance?
Also, how much do the stealerships and indy's normally charge to do that kind of work?
My new 06 motor had no leaks. But, my indy convinced me to change the rear main. I remember he said he did not want to remove the plate but instead just swap the seal. I didn't get that. Why wouldn't he just unbolt the plate and swap the rear main seal.
Well my indy guy did not purchase a new aluminum piece with seal. Just the seal by itself. I'm curious if that was the issue for the leak coming back so quick?
Or is it normal for the rear main seal to leak that quickly? I suppose releiveing crank case pressure will help with this. Maybe a catch tank will help resolve this?
Per mb orginal WIS instuctions the plate should be changed with the new seal. Also when istalling the new seal the WIS states not to use any kind of lubricant on the sealing surface of the crank or the seal itself.
So the back plate is secured with bolts and sealant, and the rear main seal is just pushed on to it
Edit: there is a cure time.. cant remember but it was pretty long!
Darn, my indy guy didn't swap the plate. He just R/I the old rear main seal with a new one. Maybe that is why it's starting to leak again. It would have been better if I left it alone until it needed replacing.
Now I am tempted to drop the trans and replace it again. But, is a new plate really necessary? Cant you just clean off sealant residue and reseal and install with new seal? Or is the plate a one time use? What about the screws?
Anyone know?
Now it's starting to leak a little bit. Looked like engine oil. Not trans oil thankfully.
Pulling the transmission is a joke-It isn't even the long part of the job. Cleaning the area of the seal plate is what takes forever, especially the lower corners....
Seal is used to lubricate crankshaft ends, you have a front and rear main seal. Above poster is correct-it is in fact the sealant that goes bad first, usually.
The only reason it would leak after being replace is install/cleaning error. If it takes 10 years for it to leak from the factory, it surely isn't product defect. If cleaned correctly and thoroughly, and correct sealant path used-there shouldn't be any leaks no time soon after repairs.
The white plastic circular disc in the photo btw is not your install tool-be careful for you DIY's, you can easily roll this seal and have to redo the whole job again-and you wont know until the thing is running at operating temperature.
Things I recommend changing to my customers if not changed previously.
1. motor/trans mount
2. transmission connector
3. shifter bushings with new clips
4. hardware/brackets that attach exhaust to trans body
5. replace your indie shop if he only replaces the seal-dumb ahsss-ahhssshole move
Yes rear mains leaking on this generation motor are extremely common. v6 or v8 na or fi...
No real common damage will happen, not to say something can't, but mostly you will just have to add oil ever so often...
Lastly-DO NOT RE-USE THE BOLTS FROM THE OLD PLATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Only two should be re-used and those are the super long ones coming from the bottom of the bell housing.....
this is a 3 hour job if he or she knows what they are doing. Usually their level of experience will determine the cost. I personally would do these all day for 500$ plus parts, however I don't own my own business and don't have employees to pay so it'll be more usually whichever shop you go to unless you know someone who will do it for the low on the side....
Good luck!
