Urgent and time cirtical, need answer frim E55 owners ASAP.
I'm in the process of buying a 2006 E55 AMG. I just found out that the car settles when it is turned off over time, although I don't know how much time it takes to do so. As soon as you start it, it raises right back up to normal ride height. Is this normal behavior for the air ride system in this car? If not, is it a common fault, and if so what is the likely cause and cost to fix? Need answer ASAP as I am in the middle of this transaction. This car is awesome in every way. I have been looking for the longest time, and this is the one, assuming this is either normal or a fairly easy fix. Thanks!
Could be the pump losing pressure through leakage.
As above, not a cheap fix at the dealer.
You need to get the car checked by an MB tech before signing the dotted line.
I'm a fairly good wrench. Not a pro but I can do some things. How hard is it for the average do it yourself car guy to replace the pump or the shocks on these cars? I just did all the control arms and suspension bushings on a W202, so I am easily capable of that type work. Given that skill level, if needed can I handle working on this system if necessary? This doesn't sound like a electronic problem, sounds more like pump, lines or shocks have a leak. How pricey is this stuff? Is it available from aftermarket or is a MB stealership the only option?
mind does it over about 7 days if I don't drive it, only seen it slammed once when the passenger side front failed, replaced it in about an hour with the arnott ones..
Mine does this in the rear after about a week. My neighbours e550 2012 does the same thing. pretty common. It will drop even faster if left out in the cold.
and like realien already mentioned... go the Arnott Way.. alot cheaper and they offer life time warranty... so if it fails you just pay for service... and definitely go to a indie shop lol.. oh and one more thing.. if it's a leaking shock see how long he's driven the car thst way.. reason I say is that driving the car thst way puts alot of stress on the actual pump... it makes it work harder.. but you mite not have a issue.. my old s-class use to sit low after a few days and it had no issue also my e63 sits low as well after non use
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I'll probably put the kibosh on it by revealing this, but after 11 years I'm still on the original bags. In preparation for at least a 7 month storage period, the car has yet to be placed on jacks, but it has been stationary for 4 weeks and it is still up. I am planning to bring a complete set or Arnott's back to Germany in July (I'm getting a little nervous - - - you know, sort of like a Christian Scientist with an appendicitis). I have also had a new Airmatic compressor on the shelf for 5 years.
In the FWIW department, I replace Airmatic air filter every 2 years when I clean the K&N's.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
'99 and '05 E55 AMG
Under the front left bumper. You'll need to pull the fender liner and/or the front undertray to get to it. The attached photo was taken while I had the bumper off to install a PLM heat exchanger. Filter is to the left of picture.
