If I had a Headbolt Coolant Leak Issue...
engine was parked and the low coolant indicator appeared. it seems i've been having a slow slow coolant leak. twice in the past 8 months i've started my engine and have had a rough idle til warmed up. Haven't seen any coolant run off anywhere on the motor so... ya...
what have people paid for this repair work at an independent repair shop?
if i need to go under surgery how reliable are the updated head bolts? $900 dollars for Weistec ARP studs are a bit extreme, but the piece of mind is worth the value.
what have folks paid for independent shop repair? i've read online that the dealer charges 5k for headbolt swap. not sure if that includes pulling the heads entirely and replacing all gaskets.
not cheap though...i've been quoted for 3500 using all factory parts from an independent if that were the situation. add in 900-1000 for Weistec studs....yowza...
as since the alerts progressively began appearing more and more i think the sensor is ok...but haven't looked to refill yet. still having AirMatic issues. gotta tow the car to a European repair shop on Friday to receive diagnosis and repair. Gonna ask them to appropriately check the cooling system as well. at what interval does the water pump generally need replacement? maybe its the waterpump...
