Auxiliary battery swapping-any acidless batteries?
Old Dec 20, 2015 | 01:22 PM
viren.89's Avatar
2004 E55 AMG
Red battery sign -Visit workshop
I read that we need this battery
Amazon.com: ACDelco ATX14BS Specialty AGM Powersports JIS 14-BS Battery: Automotive Amazon.com: ACDelco ATX14BS Specialty AGM Powersports JIS 14-BS Battery: Automotive
then I learned that this one is better ?
Amazon.com: YUASA YTX14-BS Maintenance Free Battery: Automotive Amazon.com: YUASA YTX14-BS Maintenance Free Battery: Automotive
Now I'm learning that I need to put in the acid myself and then let the battery charge and then put it in the car ? WTF ?
How the heck am I suppose to put acid in whatever it needs to go in?
Are there any batteries that already have the acid wherever it needs to be ? and all I need to do is plug the battery in and Voila ?
Thanks in advance
Old Dec 20, 2015 | 01:25 PM
viren.89's Avatar
2004 E55 AMG
Would the message go away automatically or I need to go to the dealer? to get that clear as well ?
Old Dec 20, 2015 | 01:38 PM
viren.89's Avatar
2004 E55 AMG
Also- let's say I go to Canadiantire or Advance auto parts or Napa
What do I say exactly is needed ? Any specific words I need to utter to get this specific Aux battery ?
For example for Main rear battery -I can say CCA needs to be over 850 and reserve to be 170 or better -
What are similar things I need to keep in mind of this Auxiliary battery ?
Old Dec 20, 2015 | 02:03 PM
FeelThePower's Avatar
2015 GLK350, 2003 E55, 1991 SL500
Step one:
Figure out the problem before throwing money at it.
Step two:
Disconnect both batteries individually and check voltage with multimetre, then load test them with a tester at Napa/Lordco/Autozone.
Old Dec 20, 2015 | 02:12 PM
viren.89's Avatar
2004 E55 AMG
Originally Posted by FeelThePower
Step one:
Step two:
Lol bro, problem has been diagnosed - it's the front Aux battery- the SBC doesn't Hold either and gives an error that confirms it's the front battery. Also went through all the threads.
Question was regarding "types" of batteries.
Old Dec 20, 2015 | 02:44 PM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Oem battery is so good it might be worth buying another one from the MB dealer.
Old Dec 20, 2015 | 03:21 PM
equitiesguy's Avatar
Mercedes CLS 55 AMG
What Starving said ---- You really can't beat the Bosch battery from the dealer for the aux battery, and you really can't beat the Bosch AGM improved batteries from PepBoys for the main starter battery.
Old Dec 20, 2015 | 03:24 PM
JoeNobody's Avatar
Mercedes
Maybe a micro sized lithium ion battery. Although seems pricey for little return.
Old Dec 20, 2015 | 04:14 PM
Elhonaz's Avatar
W211 E55 2003
i would buy one from dealer.. just cant go wrong there. Just my 2 cents
Old Dec 20, 2015 | 07:06 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I would stay at least a 1000 km from Canadian Tire.
Also If I were in your shoe I'd get the battery from the dealer only.
Old Dec 20, 2015 | 09:16 PM
12v 12 amp hours.
Battery is a ytx14H. Only comes in AGM, can get it anywhere car batteries are sold. It's really a motorcycle battery eh
Hope that helps
Old Dec 20, 2015 | 09:18 PM
Aftermarket or OEM will be the same quality and last as long as one another. This type of battery is only AGM
Old Dec 20, 2015 | 09:21 PM
Personally I have the ytx14h-bs made by yuasa.
I believe I spent around $75 if I remember correctly.
Old Dec 20, 2015 | 10:50 PM
amg guy's Avatar
2024 GLE 63 S Coupe 2020 E 63 S
I put an AGM battery in the front of my E55 when it was time to change batteries. I put in an interstate lead acid in the trunk. Zero problems
Old Dec 20, 2015 | 10:54 PM
viren.89's Avatar
2004 E55 AMG
People who were asking me to diagnose this- once again
The car after a drive shows 12.5 reading on the dash and on idle with Heat on and Stereo on shows 14.0 reading.
When I put the car in drive and press on SBC hold - it says "cannot be activated" ---->>> this is what confirms front battery gone.
viren.89's Avatar
2004 E55 AMG
Thanks a million everyone who posted.
I'll call up the dealer tomorrow.
Thanks again
Old Dec 21, 2015 | 09:57 AM
viren.89's Avatar
2004 E55 AMG
The dealer is charing $173 for the front auxiliary battery lol
Regular stores have it for like 100$ amazon has it for 67$ damn.
Does that seem reasonable?
Old Dec 21, 2015 | 11:01 AM
More cost effective buying it from Amazon in your circumstance, unless you like paying the Mercedes tax as well for the same product, then by all means...
Best of luck hopefully the battery fixes your problems
Old Dec 21, 2015 | 11:57 AM
cetialpha5's Avatar
That's why most people buy it from Amazon. You might find a local store like Advance Auto that might also carry it. The acid should be pretty straightforward, they just can't ship it with the acid already in there. There are coupon codes for Advance Auto that might bring the price down, check on retailmenot.com, usually some $40 off $100 code is floating around.
And $173 from the dealer is why they're called stealerships and the service department is their #1 money maker.
Old Dec 21, 2015 | 03:20 PM
viren.89's Avatar
2004 E55 AMG
ok- just put in the new battery.
1 year warranty on it- got it for 110 from local store. They poured in the acid and prepared the battery (first charge) for me -free of cost.
However, I'm still getting the red battery message and SBC hold still not working.
The UB voltage on dashboard goes to 13.8 on driving the car and 14.0-14.1 during idle with heat and stereo running.
Is it possible that due to front one having no power in it-caused the rear one to work overtime and now it'll be a while before rear one gets back to normal
levels and then everything will be okay ? or should I just swallow the pill and go to Stealership to get issues sorted out ??
What happens if there is no front battery ? what things won't work in the car ?
Even when I was getting "Convenience features off" message - my power seats were working, heat was working, lights were working -only thing off was
heated seats and stereo.
Old Dec 21, 2015 | 04:52 PM
cetialpha5's Avatar
What's the voltage when the car isn't running?
You could always take the rear one out and put it on a charger or have it load tested at a local auto parts store.
Old Dec 21, 2015 | 06:36 PM
Why don't you disconnect the main battery for a few minutes then reconnect it.
If there was a fault triggering the battery visit workshop message, even if it's fixed it won't go away until you either do this or reset it with SDS.
Old Dec 21, 2015 | 06:40 PM
To properly check voltage, disconnect the terminals completely and check the battery with a multimetre.
The secret menu voltage readout is accurate, but will not tell you the strength of your battery alone. A proper load test on the battery will tell you it's ability to retain and store power.
Old Dec 21, 2015 | 09:14 PM
viren.89's Avatar
2004 E55 AMG
OKAY FINALLY !!
I bought Aux battery put it in - I got the same error messages and SBC cannot hold nonsense - Went to buy a new Main battery and changed it- Kept getting same error messages -
started the car with main rear alone- Voltage was 14 with car idle n between 12.0- 12.4 key 1-2 I pulled out the Aux battery-cleaned the wires - re-screwed the bolts -went to start the car - NO ERROR MESSAGES ! VOILA !
THEN I realized maybe I don't even need a new battery -so then AGAIN pulled out the new main battery - plugged in the OLD battery and VOILA no error messages and SBC hold working fine.
Voltage stays between 11.9-12.4,12.5 from key 1-2 and on idle it stays at 13.9-14.
On key 2 - with music system on and heated seats and heater on. Voltage drops to 11.5-11.7
EVERYTHING RE-SYNCED and all- is well now.
Just have to go return the brand new battery now.
Thanks a lot for all that chimed in.
