Few questions for buying an E55
Old Dec 24, 2015 | 04:25 PM
tw2's Avatar
tw2
Once again thinking of making the switch.
Would a dealer be able to include SBC activation number in a pre-purchase check if requested? Max is 300,000?
Assuming airmatic functions fine, how long should most healthy cars maintain ride height after being turned off?
Maintenance is fine, but I need to make sure I can cover unexpected repairs. I have been reading this forum for 2-3 years now, SBC and airmatic seem to be the main "semi-expected" disasters E55's suffer from. Airmatic I can easily fix myself, arnotts or new control arm/coilovers. SBC I am guessing needs STAR to bleed the brake fluid and I know the pump costs $1k or so.
Is there anything else?
I would avoid 03's as don't feel like replacing radiators. Intercooler pumps are not a problem. Transmission electrohydraulic bush is also not a problem for me.
Old Dec 24, 2015 | 04:43 PM
Bean93x's Avatar
'05 E55, ‘00 ML55, ‘92 500E
Look for a decently maintained 2005 and up. I would also recommend having at least $3500 in the bank to cover unexpected repairs to the airmatic system and SBC
Old Dec 24, 2015 | 07:28 PM
Rocman8's Avatar
E55
dealers cant check the sbc count as those stars are not allowed in developer mode. airmatic should hold its height for at least 3 days. my 2006 with 118k has all original bags and the front never drops at all and the rear will drop in about a week or two.
Old Dec 24, 2015 | 10:52 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Mine is very inconsistent. Most times the rear will drop in 3 days sometimes it doesn't at all. Every once in a while overnight. It's been this way since January when I bought it. There really is no way to know unless you drive it for weeks.
Old Dec 24, 2015 | 10:58 PM
Bean93x's Avatar
Same here. The colder the weather, the worse it is.
Old Dec 24, 2015 | 11:44 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
It shouldn't drop at all unless it has a leak. How long it takes to drop depends how bad it's leaking .
Old Dec 24, 2015 | 11:49 PM
Ls1toAMG's Avatar
True but it's not that simple. The results are not the same day to day. Most cars will drop over time.
Old Dec 25, 2015 | 12:01 AM
Rocman8's Avatar
E55
Benz actually has a bulletin with normal drop specs that has a height and certain period of time. A small amount is normal. Even tires lose air when there isn't a leak. I'll try to find the bulletin.
Old Dec 25, 2015 | 12:07 AM
You're right. They should stay put for a while though. Months.
Old Dec 25, 2015 | 07:39 AM
Zed82's Avatar
E500 -03
My E55 does not drop at all during the winter storage from September to March.
Old Dec 29, 2015 | 12:49 AM
tw2's Avatar
tw2
Thanks for the advice. I found a really nice one, I just can't decide what to do, keep the CLK or go for the E55. The E is definitely faster and much more comfortable. The CLK is potentially more reliable and I know the history.
Old Dec 29, 2015 | 07:54 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Everything in life is a gamble. Enjoy the adventure!
Old Dec 29, 2015 | 02:48 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I think the SBC is 100K miles in the USA warranty. Don't forget the fuel pump unit and fuel tank... We have a recall here in the USA if fuel leak.
Old Dec 29, 2015 | 02:50 PM
Rocman8's Avatar
E55
No, the SBC is 10yr unlimited miles. The tank or components are 15yr unlimited miles. And neither are a recall they are warranty extensions.
Old Dec 29, 2015 | 02:59 PM
CharlyE500's Avatar
Good to know ! However, our car are close to 10 years now... not many has SBC warranty in this case.
Old Dec 29, 2015 | 03:12 PM
shawnoc2003's Avatar
E55, Audi S4
No regrets here.
Thankfully Arnott offers airmatic retrofits but so far I haven't needed them for my 05. If I don't drive it for a few weeks, the rear's will bleed out if its cold but so far I just restart the car and everything has been fine (for the last 2 years).
If I could just get rid of the stupid key reminder every time I open the door, it would be the perfect family car.
Old Dec 30, 2015 | 07:33 PM
tw2's Avatar
tw2
Yep exactly the conclusion i came to. I am going to go for it.
