share you trick to removing the 2 long 8mm bolts for the BWK pulleys
Old Dec 28, 2015 | 06:57 PM
06cls55amg's Avatar
06cls
so one of my grease seals popped out and bearing is running dry on the pulley underneath SC pulley. need to remove the thing, but iirc i went thru hell installing these botls and a 8mm allen socket is to long and hits fan shroud. other than using a short 8mm allen at a 1/4 turn, does anyone have any input?
Also do you guys have bunch of gunk built up around the ID cavity?
Old Dec 28, 2015 | 07:12 PM
hayseed's Avatar
04 e55
I cut an allen wrench down to about an inch long or so then used a combination wrench the size of the allen... it would be even faster if you use a box wrench with a built in ratchet.
Old Dec 29, 2015 | 04:24 AM
ss.dna02's Avatar
05 E55 AMG
I used a long ratcheting wrench with a small bit. Worked like a charm
Old Dec 29, 2015 | 07:39 AM
sexyxe's Avatar
04 E55
Allen key with ball heads
Old Dec 29, 2015 | 04:19 PM
06cls55amg's Avatar
06cls
thanks guys, gonna swing by the ole harbor freight and see what they got.
Old Dec 30, 2015 | 04:55 AM
ss.dna02's Avatar
05 E55 AMG
They dont have anything. I went there and no luck on a long ratcheting wrench or a small bit.
I bought them on amazon.
Snap on carries a long wrench and bits too but I didnt think I needed to spend money on those parts since im not going to use them often.
You can also buy this kit but it will take longer since it doesnt ratchet like a wrench would.
TEKTON 25291 9-pc. Star Key Set, T10-T50 - - Amazon.com TEKTON 25291 9-pc. Star Key Set, T10-T50 - - Amazon.com
Old Dec 30, 2015 | 06:51 AM
sexyxe's Avatar
04 E55
What about an 8mm headed bolt, slap a few nuts on it, use it as a small bit.
Old Dec 30, 2015 | 08:42 AM
RikTT's Avatar
A bunch of TT's
I truly would have preferred a normal 6 point headed bolt in the first place to be supplied.
Old Jan 2, 2016 | 03:57 AM
gjunon's Avatar
04 E55 AMG
Fan shroud is easy enough to remove.
Old Jan 4, 2016 | 08:53 AM
rockthemullet's Avatar
2005 Mercedes E55 AMG
This.
When I've tried to work on anything in the front without removing the fan, I just end up cutting my hands up and removing the fan anyway.
