Anyone ever corner balance after coil over install?
Corner balancing is great when you take all the compliance out of a car but with your rubber mounted subframes, engine mounts and suspension arms you are only chasing your tail trying to corner balance the car.
Now as for the rubber bushings issue, I think they would have an effect on alignment under deflection but wouldn't change the corner weight. Or am I wrong ?
Alignment affects corner balance. that's why you get a rough corner balance on a race car, then do the alignment then corner balance again.
Sway bars need to be disconnected when doing a corner balance then need adjustable end links to take out preload which affects corner balance.
This is why it takes almost a full day to properly corner balance a race car from a zero build.
