May have locked my key inside my trunk help?
AAA came out and broke in. took about 25 seconds...lol
I thought maybe the key was stuck in between the seats but it's not.
I have keyless go.
I think it might be in the trunk but the trunk release won't release the trunk?
dealer says new key is $360 +$160 for coding!!!! omg!!
I have keyless go.
Have you started it put it in gear then turn off. Then try to pop it. It won't open if car is started. Breaking in my have set a safety thing to disable the button
I also don't think you can lock your keys inside. If it is keyless go, why not try what LS1 has said? It will let you know if your key is in the car at least (or is the sensor more accurate than just being inside the car?)
If you had someone unlock your car without using key then your car has you locked out of trunk
Here is a DIY I found
https://mbworld.org/forums/mercedes-...arm-armed.html
2005 E55, GMC Whipple Supercharged Quadrasteer Denali Pickup,Big Bored Hyabusa with nitrous
You could pull the rear seat out . Should be able to hit the open button inside the trunk with a broomstick or long rod. Kind of a pain but it would beat buying a key.
