ecumaster piggyback upp and running
You just said you gained 100 hp by adding meth, and 10 AFR is rich as ****.
I like what you're doing. Don't get me wrong. I'm still looking for an easier way to tune myself. I just prefer to be on the stock Ecu.
but im not living close to a tuner off stock ecu
so this is the route i was forced to do because off not so god mailtunes
im not your tuner either
ask your stock ecu tuner how to tunemailtune is set at 10,6 afr and -15 on the timing whitout meth, when meth is on=sub 10
adjustment is made and try again
big adjustment down low makes the cooldstart work butt allso makes the fueltrims go bannanas, so its a basicaly to find the goolden spot and not uppset the fueltrims
blackline is bost thru stock mapsensor
i think it is a little to mutch flutterating
has somone else logged real boost?
not thru a to slow obd logger
converted to psi is hovering from 14 to 18 psi
i dont trust the dyno utility 100%
so im counting time on the loggs 3rd gear 1500-6500rpm pulls
im counting intervall from 2000-6000rpm im now down on 9,1s (dyno shoved above was 9,7s 2000-6000rpm)
is it a good time?
car is working great
cold starts issues is solved, simply by turning ignition on/off beffore start
iff it is the 550cc injectors or loosing fuelpressure when sitts still dosent matter this procedure allways work
other than that i have been trying loots off different lenght belts for the sc
im not real pleased whith the log on the boost going upp and down 4-6 psi
its making it hard to tune and leaves power on the table
maybe its not possible to have a good nice boost curve whith the 72mm pulley?
it just feels weak all the way whith this tires on, dyno mode made no diiference
will try a dyno run whtih this setup on later(hope its down on power)
