How do I get my car in neutral without turning on the engine?
"In the case of power failure, the transmission selector lever can be manually unlocked to tow the vehicle.
Depending on production date, your vehicle is equipped with cup holders in either the center console or in the center armrest.
Open the storage compartment on the center console.
Take out the cup holder.
Hold the cover at a 45 degree angle. Insert a suitable object like a pin through the hole and press the pin downward.
Remove pin.The selector lever is locked again when moving it to position P."
Hope this helps.
Hope this helps.
