Tranny fluid leak/ tranny slipped into neutral
Old Mar 25, 2016 | 09:58 AM
havok209's Avatar
'18 GLS 63
Been slipping into neutral on me a few times under uphill acceleration last couple days. This morning there was a puddle in the driveway and again after a short drive this morning. Just bought the car 4 days ago knowing it was going to need work.
What am I looking at as far as potential causes, repair, and damage done to tranny?
It's my first MB so any help is appreciated. Thanks
Old Mar 25, 2016 | 10:07 AM
Dublinoh's Avatar
E63 AMG 2007
For others to help you...model and year, can you have someone check for codes? Welcome to the forum.
Old Mar 25, 2016 | 10:13 AM
havok209's Avatar
'18 GLS 63
04. E55. Nothing too crazy or specific. Also as soon as I get more time, gonna look into a STAR.
Old Mar 25, 2016 | 10:41 AM
Hulk's Avatar
A Merc
Don't drive around with low fluid as you can damage the trans. Check the pilot bushing aka 13 pin connector, that's where leaks usually are but a puddle as you say is lot. Get a trans oil dipstick ans see where you are at
Old Mar 25, 2016 | 10:56 AM
havok209's Avatar
'18 GLS 63
That was my concern about causing damage. It's at the shop to get the some stuff done I don't have time to do. The owner/mechanic has an E55 himself. He said he'd check it out. Just trying to get a bit of an idea on what to expect. I'll get an oil dipstick for sure.
Old Mar 26, 2016 | 12:39 AM
Rocman8's Avatar
E55
best case = 13 pin connector leak
worse case = trans front pump leak
Old Mar 29, 2016 | 06:12 AM
havok209's Avatar
'18 GLS 63
Turned out to be the bottom of the two lines that run into the radiator. I went ahead and just installed an external one. All is well now. Thanks gents.
Old Mar 29, 2016 | 11:02 AM
Elhonaz's Avatar
W211 E55 2003
glad you got it sorted out!
