Replaced all front bushings, still hear slight clicking noise going over speed bump.
The Wurth HHS-2000 grease sprayed on the sway bar bushings helped quell the noise, but in the end, it needed a new sway bar (which has the integrated, non-replaceable sway bar bushings on them). As DVC mentioned (and also an indpendent mechanic suggest I do, as I stopped going to the dealer), have your mechanic disconnect the sway bar end links to the sway bar, so it takes pressure of the sway bar bushings. Test drive it around over a rough patch of road or over expansion joints to try and replicate the noise, and if the noise disappears, you know it's the worn sway bar bushings. You'll then need to get that sway bar replaced with a new one so you have fresh bushings on there. Good luck.
http://www.ebay.com/itm/like/181460891693?lpid=82&chn=ps&ul_noapp=true
It's for the HHS-Plus, which superseded the HHS-K, which superseded the HHS-2000.
Here's a few other resources:
Bavauto.com (where I originally got my HHS-K once upon a time)
Item: 893106
$24
http://www.bavauto.com/fland.asp?par...ba0aAvVn8P8HAQ
http://www.fswerks.com/products/8931...Q5IaArGP8P8HAQ
Maybe its the power steering bushings also who knows. We'll see.
It seems unlikely at first because it's definitely more of a "click " sound than you'd expect from a bad bushing ,but give this a try first. Get a can of synthetic lubricant (I used royal purple) that has a little red tube you can stick in the cap for small areas. Jack up the front of the car and turn the wheel all the way to one side, and you'll see the sway bar bushings where they mount to the frame. There's a tiny opening in the side of the bushing where you can fit that little red tube into. Soak it until it runs out the other side, then spray the sway bar end links also while you're there. You may have to drive it around the block and repeat, depending how dried out it is.
I drive my E daily, and have had to lube those bushings twice in the past 14 months, but it definitely works at least for a while. Replacing the sway bar is on my "to do" list, but since there's a 5 minute/$5 fix, that job isn't even on the top 30 for now
Will lithium greese spray work? it seems very sticky and has high pressure with the red straw.
No more rattle
... now I have ABS/ESP/Active Lights Unavailable up on the dash.
Hopefully I can just 'resync' everything and it's an easy fix...
1. Jack up Car
2. Remove Underpanels
3. Remove 4 - 20mm (I think that's what they were) bolts that protect the steering rack AND mount the rack to the body of the car.
4. Lower rack about and remove old bushings. I found it easier to pry the lower ones out, and then use a screwdriver or something to push the top ones out.
5. Install new bushings. Take care to note orientation. You'll see what I mean.
6. Lift rack back up into position.
7. Align protective plate, and put the 4 bolts back in.
8. Put panels back. Lower car.
Figures 8-10 in here. Nothing else needs to be disconnected. There's just enough room to drop it about an inch to squeeze the top bushing in.
http://www.pelicanparts.com/techarti...eplacement.htm
This was inspired by the C-Class guys. I figured ours couldn't be much different.
https://mbworld.org/forums/c-class-w...move-rack.html
No more rattle
I'm going to swap out my steering rack bushings and take a look at my sway bar while we're in there. Got the lube ready for sway bar too.
OK so wait, you did control arms or thrust arms?? Control arms hold the air springs up. Thrust arms go front to back and are aluminum.
End links to steering rack? Just end links or did you replace the middle shafts too with the new boot etc?
And upper/lower ball joints. And sway bar endlinks.
And a few weeks ago I did Inner AND Outer tie rod ends because my boot had torn and allowed debris to wear out my pass side inner tie rod. So, again, if I'm in there, might as well do everything and be good to go for a while
Let me know if you have any questions. On a DIY scale of 1-10, it's probably a 6 if you're working by yourself, only because some of these things can be heavy when you're on your back.
I have the jack accessory that slides front to back on the inner rails. I can use it to lift the front or rear of the car with ease. Almost like having a hybrid 2/4 post.
I am curious if the wandering you guys report is unrelated to this issue. I have always had tramlining in every single car I own with staggered wheels. And given our cars are more performance oriented, the slightly more aggressive alignment could certainly contribute that. My car had excessive tramlining when I first got it but an alignment really helped to minimize the effect.
