Replaced all front bushings, still hear slight clicking noise going over speed bump.
Old Apr 21, 2016 | 05:10 PM
  #76
06cls55amg's Avatar
06cls
dont mean to thrad jack but whats the best way to check the subframe bushings?
Old Apr 21, 2016 | 05:46 PM
  #77
Max.H's Avatar
E55
Originally Posted by Sir-Boost-a-Lot
Check your rear lower ball joints, and also the bushings/bolts that attach your rear subframe to the unibody.
Good thinking Chris, Got any illustrations or tips on how to check if they are bad? I imagine they are.
Old Apr 21, 2016 | 07:00 PM
  #78
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Support the car on jack stands by the unibody to take the load off the suspension. Then use a pry bar to check the components for play. I know a lot of guys will do it with no problems, but I don't like to pry on aluminum components directly. I'll put a block of wood or thick plastic (bondo spreaders work great) between the pry bar and the part as to not mar the surface.
Did you lube the sway bar bushings yet?
Old Apr 25, 2016 | 12:02 PM
  #79
06cls55amg's Avatar
06cls
http://www.pelicanparts.com/techarti...Index-W211.htm
found this on pelican parts...
friday i put the car on the lift and did the 9-3/12-6 pulling on the wheel back and fourth as hard as i could and could not for the life of me feel,see, or hear any play.
going to spray the sway bar bushings with the wurth oil, change steering rack bushings .,and rear shocks. then check the rear suspension for play with a pry bar..
Old Apr 25, 2016 | 12:07 PM
  #80
mkiv_tdi's Avatar
Jetta TDI [Daily] , Audi A8L [Sold], '12 STI [Sold], '06 E55 [Sold], '05 S500, '15 GLA250
You won't feel play in the Sway Bar by checking the wheels.
What works, however, is getting the car up on those plastic heavy duty ramps. Drive up on them so the front of the car is raised.
Then get under the sway bar and grab it as if it were a barbell, and "bench press" it up and/or pull yourself up to it. You'll be able to feel it "creak" if your bushings are sufficiently worn.
Old Apr 30, 2016 | 05:59 PM
  #81
kponti's Avatar
E63
Guaranteed 18rwhp and 26rwtq with the UPD intake over k & n filters
Old May 2, 2016 | 11:53 PM
  #82
Max.H's Avatar
E55
Is it more the bushings the the sway bar end links? How was yours, worn out or still looked ok but changed anyway?
Old May 12, 2016 | 05:10 PM
  #83
Rallyboy383's Avatar
2004 E55
Did not mean to post.
Old Jul 6, 2016 | 03:42 AM
  #84
Marco Torino's Avatar
c205 c300 coupe
I want to put a c63 difusor and tips on my c300
Do you know where can i find it?
I only see difusors for the sedan
Old Jul 6, 2016 | 04:17 AM
  #85
skylinrcr01's Avatar
2004 E55, Triumph Speed Triple
wrong forum dude.
Old Jul 18, 2016 | 12:18 AM
  #86
jay rick's Avatar
C63 2009
My mechanic replaced the pedal and the problem is gone. But im not sure which no. code was throwing but he said it was pedal sensor.
Old Jul 18, 2016 | 05:27 PM
  #87
Max.H's Avatar
E55
Got some brand new sway bar bushings. I'm going to take the advise of the guys here in this thread. Just need to find some time to put it on the lift. I hope it's that.
Old Jul 18, 2016 | 06:11 PM
  #88
BC928's Avatar
2006 E55, Various other German and ‘Murican
You bought the sway bar bushings separate from the sway bar? I was under the impression it was only sold as one piece, because they were molded.
Do you have a black and yellow license plate and turn left onto miramar from Eastgate to go home from work?
Old Jul 18, 2016 | 06:48 PM
  #89
Max.H's Avatar
E55
I was too. but, I randomly found a pair of brand new bushings for sale on ebay. 1 pair left so I said what the heck. I'm going to see what the deal is.
Nope, that's not me. No blk and yellow license plate.
Old Jul 19, 2016 | 10:27 AM
  #90
mkiv_tdi's Avatar
Ummm, if those are legit, i think a lot of us would want to know more details. Pics? Link? I'm skeptical... lol
Old Jul 28, 2016 | 02:12 PM
  #91
Elhonaz's Avatar
W211 E55 2003
you guys have any update on this?
Mean while i changed my steeringrack bushings too, just for fun. It was very easy and simple to do like allredy said here. Took some pics too.
old vs new. old was barely 24mm in deameter and very dried out. new was just over 24mm in diameter
Rack comes down nice after removing the 4 bolts
old in place
more than enough room to work on
Old Aug 8, 2016 | 07:20 PM
  #92
agregory23's Avatar
E63S
How did they end up working for you? Any more clicking?
Old Aug 9, 2016 | 04:14 PM
  #93
Max.H's Avatar
E55
Not yet . Sorry I could not be more help to you. Have not been driving the AMG much lately. I have been gathering a bunch of parts I need to service the car. Now I could have a leaking rear air spring. Now a new height sensor or airmatic spring. So the list continues.
I will update the thread when I get to it. Probably within the next few months.
Old Aug 10, 2016 | 03:18 PM
  #94
CarbonHan's Avatar
E39 M5, E71 X6M, W211 E63 AMG, W218 CLS63 AMG
I'm going to be dropping my steering rack within the next couple of weeks so this thread was absolutely priceless with the amount of knowledge i've gained from it.
I have a very slight whistling, squeaking sound thats present when going about 25mph coming from the passenger front axle area. From the research i've been doing it looks like my steering rack is making the noise... but reading through this thread, somebody mentioned that ball joints can make squeaking noises.
Any ideas? Id much rather spend the money on ball joints than on a freaking steering rack lol.
Old Aug 10, 2016 | 03:23 PM
  #95
BenZ190D's Avatar
87-190D 2.5 5-Speed Manual, 2004 C230 Kompressor Sport - 6-Speed Manul
you may want to get the tie-rad ends (inner & outer) checked at a realignment shop. also check if your stabilizer bar link joint is loose/worn out and need replacement. The latter is an easy job that takes just 30 min.
Old Aug 10, 2016 | 04:17 PM
  #96
Elhonaz's Avatar
W211 E55 2003
Have a qualifield person check the front end. Sometimes the little squeaks can be HARD to find. My lower balljoints made a squeak when they went bad. First only while driving, even a slightest of a bump or roughness made them squeak and it got progressivly worse quickly.
Old Aug 16, 2016 | 07:17 PM
  #97
maxzero's Avatar
2016 w205 c300 amg sport
https://instagram.com/p/BJLzoudAXoW/ i bit upgraded my interior
Old Aug 22, 2016 | 02:10 PM
  #98
VinnyGirl's Avatar
C-250
Noise
I have a "popping" or "creaking" noise I hear underneath after I have driven on the highway and am going at a lower speed. The dealership replaced the sway bar and links but that has not gotten rid of the noise. Has anyone else had this issue?
Old Aug 25, 2016 | 10:13 PM
  #99
forcefed4door's Avatar
05 E55, 06 Audi S4
Could be the air struts making noise if there the originals.
Old Aug 28, 2016 | 05:37 PM
  #100
dustinN's Avatar
09E350, 07E63, 13CLS63
Wrong thread, removed.
