Replaced all front bushings, still hear slight clicking noise going over speed bump.
So, I had my car raised up and I could see the front sway bar bushings everyone is saying will wear out and could have metal contact and that could cause the clicking noises. Well, I bought new sway bar bushings but my buddy and I looked and they didnt seem to be smashed up like I was expecting to see. Old ya. Dry ya. But, not chewed up. I should have snapped a pic but the front sway bar bushings did not look collapsed.
I forgot to remove the sway bar end links to go for a drive though. So. I will get back at it when my new arnott airmatic springs and shocks arrive.
There used to be some threads about clicking noises and I think someone said it was the airmatic shock itself. Don't quote me but, something about the original airmatic was making noises like I'm having. Anyone have experience with an airmatic front shock making clicking noises when going over bumps?
Will check update again to give you guys the final conclusion.
Good luck on yours brother
if the noise is up and down could be any suspension component as front shocks they like to make noise especially rebuild arnott struts
That is a good point. Looking at the sway bar bushings up in the air is one thing, 4k lbs car weighing down on the sway bar bushings on the ground is another thing. Ive got the new sway bar bushings ready to install as well as the power steering rack bushings
Was the sway bar swap easy or hard to do? Any tips?
What kind of noises? Squeaks or like a clikity clack racket
. I have factory airmatic shocks.
My mechanic said that you can slip a washer in between the rear bolts of this plate and it should stop the plate from rubbing the sub frame when it flexes. So I did that, and replaced the rack bushings at the same time. While its better, and while the steering feels great with the new bushings, I still get a quiet popping sound when turning during parking.
The only thing that is left that hasn't been replaced is the driver side strut. But, I don't understand how it could make noise while turning? I figured a bad strut on this car would cause airmatic issues, or an up/down motion based noise...
I've used Wurth HHS-2000/HHS-K high pressure penetrating lubricating oil to silence the bushings, and it lasts for a good while.
Weird how lubricating sway bar bushings would eliminate metal on metal clickity clack sounds. Squeaks I can understand. I will report back after my airmatic parts arrive and when I install the remaining steering rack bushings and sway bar bushings.
Got the sway bar bushings and steering rack bushings replaced new airmatic pump, arnott air springs and bilstein shocks installed. Wow, what a difference.
The clickity clack sound is gone! Turns out the sway bar bushing were collapsed as people have mentioned in this thread and the steering rack bushings were also worn out. The car drives like new. Feels very tight once again. Very pleased with the results.
Also, anyone who was following my thread about the airmatic issue. It turns out my shock was collapsed and leaked all the fluid and that was the same side I had issues with the airmatic spring. So new shocks and new arnott's fixed that. Check your shocks guys! If it's leaking fluid it will cause accellerated wear on that air spring.
Another reason why, I highly recommend keeping up with service on your E55/E63. It's not cheap. Anyone say's otherwise, they don't maintain them well. But, If maintained well. These cars are very rewarding. Merry Christmas everyone!!
The clickity clack sound is gone! Turns out the sway bar bushing were collapsed and the steering rack bushings were also worn out. The car drives like new. Feels very tight once again. Very pleased with the results.
I think i need to replace the steering rack bushing but i could not find any info on the web for the w204.
Do you happen have any part numbers for these bushings?
Is this the steering rack bushing you're referring to? http://www.pelicanparts.com/More_Inf...SVSI=3889#tab2
Yes, those are the ones. The car feels like new again. Happy new years buddy!
On a side note. Were going to try the new Godspeed Mono Max coilovers on a C63 and E63 and do a review about them.
What is the best choice for mostly dry CA conditions? Seems a lot of people liked the Michelin Super Sports, but they seem to be replaced now with the Super Sport 4S ? has anyone put these on their C450 or C43?
Also, has anyone done any spirited track driving with these Michelin SS 4S or SS tires? I'm going to do a couple track days, probably not going to go crazy with my daily driver and have read a couple of review on tirerack that say their side walls of these SS 4S peeled off after 3-4 hours on the track. Sort of doesn't really make any sense as the tire is recommended for porsche 911 and ferrari 4xx so I can't imagine they are road only.
Any reports of quality and performance, ride, noise and stick would be MOST appreciated.
disclaimer: I'm going to cross post in the main C450/43 thread too.
Steering Rack Bushing - 211 463 03 66
Front Sway Bar end links - 211 320 39 89, 211 320 38 89
Rear torsion bar to control arm - A2113203389
Looking to replace all the rear subframe bushings soon.
I'll start a post on this since i haven't seen anyone post any for w211/219. Two special tools are required.
Thanks.
The old ball joints were all pretty bad.
Anyone ran into this before? I'm thinking it's sway bar end link? I can re grease the sway bar bushings and change end links.
Sorry if this specific question has been asked before.
I can't imagine its good. I thought for sure all the ball joints would correct this.
I began disassembly and when the Thrust Arm was isolated the inner bush made the same noise as I moved it to its extremes.
I understand that to accurately diagnose these components the vehicle should be resting on its four wheels. Then apply squeezing force using channel locks onto the top nut and bottom cup, so any movement can be viewed. Push and pull on the top or sides of the tire can also reveal play.
I can see the ball joint is bad on the knuckle and I can hear the $26 Thrust Arm inner bushing, and I've probably missed one.
While I'm in there working on the lowers, I compare solutions because I have the ball joint and bush tools: Complete Rear Arm $70+Front $120=$190.
or All the bushings & ball joints individually=$100.
Add $50 knuckle ball joint not included either way.
If there's still noise I'll do the uppers.
Still noisy, the outer tie-rod end and hope the rack ends are okay.
https://www.ebay.com/itm/371165299026
Along with a new set of wheels/tires helped restore my faith cruising at highway speeeds.and above
otherwise I would have tried it myself! If anyone disagrees, I’d be very interested to hear how “smoothly” it went!
