Modded e55 vs modded c63 opinions!
Old 04-07-2016, 12:20 AM
AMG__POWER's Avatar
2023 e450 cabriolet, 2015 s550, 2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2014 e63
Hey guys just wondering how my car would stack up against a modded 2012 c63... Here's my mods, stage 2 tune, mid length headers, 83mm pulley, heat exchanger and a new ic pump that c63 has long tube headers, tune and intake.
What do you guys think
Old 04-07-2016, 01:04 AM
Ruthle55's Avatar
e55 amg
Id guess probably dead even. You'll probably pull a little up top.
Old 04-07-2016, 10:17 AM
AMG__POWER's Avatar
I was thinking the same maybe a 40-100 pull, I also forgot to mention he will have 3 people in his car I will have 4
Old 04-07-2016, 11:45 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
depends on driver ... weather condition the health of the cars ... it should be close .. but I think high high end wise will be the c63
Old 04-07-2016, 01:30 PM
AMG__POWER's Avatar
Do you think that if my car is running healthy which it is always maintained never beaten on... That I could win 40-100 roll?
Old 04-07-2016, 02:15 PM
dchl21's Avatar
ya I think you would by alittle bit. leave in "s" mode ...hold left paddle drop to lowest gear... floor it and let car shift itself..
1/4 tank of gas... before you go do a sneaky ecu reset.
Old 04-07-2016, 02:17 PM
AMG__POWER's Avatar
Do you think I should drop from 3rd to 2nd? And let the car shift after
Old 04-07-2016, 02:35 PM
johnnyblaze's Avatar
CLS63S
Roll Race at 40mph the C63 will take it
Lighter - better transmission
Dig race the E55 will take it
More torque. You can build a big lead fast before the C63 begins to reel.
I had a Stage 3 E55 with 562whp and it was safe to say my C63 with 481whp felt faster from a roll.
Old 04-07-2016, 04:36 PM
Ruthle55's Avatar
e55 amg
Why are you going to race with so many people in the car? and why are you posting a what if? Just race.
a100steaksauce (04-11-2016)
Old 04-07-2016, 08:52 PM
FinanceMike's Avatar
CLS55
My bet would be on the C63 with the headers and tune. Less weight, no heat soak worries and a much better transmission for roll racing.
I've watched 63's with headers and a tune dyno around 480whp
Old 04-07-2016, 08:54 PM
AMG__POWER's Avatar
[QUOTE=Ruthle55;6764261]Why are you going to race with so many people in the car? and why are you posting a what if? Just race.[/QUOTE
Becusse I am going to a car show and there's this many people in my car, I just wanted opinions...
Old 04-07-2016, 08:55 PM
AMG__POWER's Avatar
With the current mods I have shouldn't I be around if not more than power and a lot more torque?
Old 04-07-2016, 09:12 PM
CLS55
You certainly have more power. But don't be surprised if he jumps. Those things are no joke with headers/tune. Down here at PBIR, I've watched them run mid 11's @ 125 with headers and a tune.
I'd run him down low so you can get the most out of your torque advantage.
Old 04-08-2016, 03:12 PM
Max.H's Avatar
E55
That works best when you're driving and need to suddenly overtake.
In a actual planned 60-130 roll race. you want to start in 2nd gear, leave in S mode and just mash the gas. The car will do the rest. 40 mph is really low c63 has advantage.
If your car has to drop down gears ,you lose a lot of time. Better to start direct in gear and mash the gas.
AMG__POWER (04-11-2016)
Old 04-08-2016, 03:19 PM
romeomikehotel's Avatar
cls55 amg
I roll raced one when i had a 77mm pulley and a tune and pulled pretty hard on it but I think it was stock. I would think you would win but I could be wrong. I also think he's going to suffer more from the added weight of passengers than you will. And Max. H is right, try and race from 60.
The following 2 users liked this post by romeomikehotel:
Max.H (04-08-2016), Zod (04-10-2016)
Old 04-11-2016, 03:56 PM
Flo1989's Avatar
CLS 55, Audi A7, Range Rover Sport
I'm now assuming I'm wrong but I never did the "sneaky ecu reset" ever since I installed my EC tune. Doing this wont override it back to stock?
Old 04-11-2016, 05:09 PM
AMG__POWER's Avatar
Nah it doesn't I believe it just resets the shifting points back to aggressive factory form becusse the car adapts to drivin style
AMG__POWER's Avatar
For sure thanks
Old 04-11-2016, 05:16 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Nah it doesn't I believe it just resets the shifting points back to aggressive factory form because the car adapts to driving style
Correct. I specifically asked Eurocharged this after getting my tune.
Old 04-11-2016, 05:37 PM
AMG__POWER's Avatar
Does it make a noticeable difference from your experience?
Old 04-11-2016, 05:56 PM
HeissRod's Avatar
What? Resetting adaptives? Yes.
Old 04-11-2016, 06:52 PM
Flo1989's Avatar
Wow for 3 years now I thought I would interfere with my Eurocharged tune. Glad you all were able to clear that up.
Old 04-11-2016, 07:42 PM
dchl21's Avatar
L O L ! that's horrible !! but its ok ...if your car's battery ever died before it resets too.
Old 04-11-2016, 08:41 PM
Hulk's Avatar
A Merc
As max said put in 2nd and S drive and go, I would be worried of spinning more than anything else.
Old 04-11-2016, 09:46 PM
HeissRod's Avatar
https://mbworld.org/forums/w211-amg/...ml#post5627913
Quick Reply: Modded e55 vs modded c63 opinions!
