Has anyone put these EXACT rims on your w211 AMG??
09 E550 Prm1+Sport 2003 E500 (SOLD)
I'm considering buying a straight silver wheel so I don't have to worry about the OEM gray matching. The original OEM 5-spoke AMG wheel was straight silver, so I'm thinking the silver split 5-spoke would look good. Been looking at these:
https://www.usarim.com/19-inch-merce...s-benz-wheels/
This link below is the best thing I've found to compare tire/wheel sizes. This little app allows you to input the OEM wheel/tire size on the left and your new wheel/tire size on the right ... then it will tell you exactly what differences you will have with suspension clearance, fender clearance, wheelwell clearance, and speedometer changes. Gives you a good comfort level before pulling the trigger.
http://www.rimsntires.com/specspro.jsp
The OEM stock wheel for my W211 E550 (same as E63):
Front Wheel Specs: 18"x8.5", 38 offset and 5x112 bolt pattern
Rear Wheel Specs: 18"x9", 39 offset and 5x112 bolt pattern
The OEM stock tire is:
Front: 245/40-18
Rear: 265/35-18
Front: 245/40-18
Rear: 265/35-18
my car came with these same wheels, 2 of the stickers are missing. the fronts have spacers, I haven't looked closely enough to determine what the ET of the wheels are haven't measured the spacers either.
